jQuery UI Widgets Forums Angular valueAxis title and timestamps on xAxis not showing
This topic contains 3 replies, has 4 voices, and was last updated by  Stanislav 7 years, 2 months ago.
  • mhussajn
    Hi, i’m building an app using Angular CLI and jqxChart. I started the project from scratch today and noticed that you have updated your guidelines and package (jqwidgets-scripts instead of jqwidgets-framework). So i installed new package, followed your new guidelines and copied my code which uses some of the code from chart demo – “Live Updates Every Second”
    Now the title on valueAxis and timestamps are not showing.
    before:
    before
    after:
    after
    ts file:
      @ViewChild('myChart') myChart: jqxChartComponent;
      data: any[] = [];
      xAxis: any =
          dataField: 'timestamp',
          type: 'date',
          baseUnit: 'second',
          unitInterval: 5,
          formatFunction: (value: any) => {
              return jqx.dataFormat.formatdate(value, 'hh:mm:ss', 'en-us');
          gridLines: { step: 2 },
          valuesOnTicks: true,
          labels: { angle: -45, offset: { x: -17, y: 0 } }
      valueAxis: any =
          minValue: 0,
          maxValue: 100,
          title: { text: 'Index Value' },
          labels: { horizontalAlignment: 'right' }
      seriesGroups: any[] =
              type: 'splinearea',
              alignEndPointsWithIntervals: true,
              series: [
                { dataField: 'value1', displayText: 'Core 1', opacity: 0.7, lineWidth: 2},
                { dataField: 'value2', displayText: 'Core 2', opacity: 0.7, lineWidth: 2},
                { dataField: 'value3', displayText: 'Core 3', opacity: 0.7, lineWidth: 2},
                { dataField: 'value4', displayText: 'Core 4', opacity: 0.7, lineWidth: 2},
      ngAfterViewInit(): void {
          const data = this.myChart.source();
          const timer = setInterval(() => {
              if (data.length >= 100) {data.splice(0, 1); }
              const timestamp = new Date();
              timestamp.setSeconds(timestamp.getSeconds());
              timestamp.setMilliseconds(0);
                  data.push({
                      timestamp: timestamp,
                      value1: Math.floor(Math.random() * 99) + 1,
                      value2: Math.floor(Math.random() * 99) + 1,
                      value3: Math.floor(Math.random() * 99) + 1,
                      value4: Math.floor(Math.random() * 99) + 1,
              this.myChart.update();
          }, 1000);
    Ivo Zhulev
    Hi mhussajn,
    Can you please share and the HTML markup?
    Ivo
    ponraj
    We are having the same issue as well, it seems the value axis title and x-axis labels are displayed under the chart [while debugging the elements, they are there but not visible.]
    Mockups:
    padding: any = { left: 10, top: 5, right: 10, bottom: 5 };
    titlePadding: any = { left: 50, top: 0, right: 0, bottom: 10 };
    xAxis: any =
    dataField: ‘ChartDate’,
    type: ‘date’,
    baseUnit: ‘month’,
    title: { text: ‘Business Date’ },
    unitInterval: 3,
    tickMarks: { visible: true, interval: 1 },
    gridLinesInterval: { visible: true, interval: 1 },
    labels: {
    angle: -30,
    rotationPoint: ‘topright’,
    offset: { x: 0, y: -25 }
    valueAxis: any =
    title: { text: ‘Count’ },
    labels: { horizontalAlignment: ‘right’ }
    seriesGroups: any =
    type: ‘line’,
    series: [
    { dataField: ‘Unique_Count’, displayText: ‘Unique Count’ }
    Stanislav
    Hello ponraj,
    We are sorry for the inconvenience!
    For now, use v5.4.0 of jqwidgets.(You can still use v5.6.0 on the jqwidgets-ts files)
    We will do our best to fix the problem as soon as possible.
    Stanislav
