jQuery UI Widgets › Forums › Plugins › Validator, Drag & Drop, Sortable › Validator for Zip Code is using SSN
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 11 years, 11 months ago.
I was trying to implement a simple data entry form and my zip code was never validated correctly. I went into the sample code and noticed that zip code is expected in ssn format. This is also true for the unit tests. Am I imagining something, or is the zipCode validator broken?
Also, how can I easily mask a validator that is not required? Basically, I want to make sure that, if I have a phone number, it will be correctly entered but I don’t want to insist on having one.
I really like these widgets. I’m evaluating for now, but am likely to be purchasing soon. Thank you.
The following modification of our sample shows how to correctly validate ZIP Code:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxvalidator.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/globalization/globalize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcalendar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdatetimeinput.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmaskedinput.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxinput.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme() $("#register").jqxExpander({ toggleMode: 'none', width: '300px', showArrow: false, theme: theme }); $('#sendButton').jqxButton({ width: 60, height: 25, theme: theme }); $('#acceptInput').jqxCheckBox({ width: 130, theme: theme }); $('#sendButton').on('click', function () { $('#testForm').jqxValidator('validate'); }); $("#ssnInput").jqxMaskedInput({ mask: '###-##-####', width: 150, height: 22, theme: theme }); $("#phoneInput").jqxMaskedInput({ mask: '(###)###-####', width: 150, height: 22, theme: theme }); $("#zipInput").jqxMaskedInput({ mask: '#####-####', width: 150, height: 22, theme: theme }); $('.text-input').jqxInput({ theme: theme }); var date = new Date(); date.setFullYear(2000, 0, 1); $('#birthInput').jqxDateTimeInput({ theme: theme, height: 22, value: $.jqx._jqxDateTimeInput.getDateTime(date) }); // initialize validator. $('#testForm').jqxValidator({ rules: [ { input: '#userInput', message: 'Username is required!', action: 'keyup, blur', rule: 'required' }, { input: '#userInput', message: 'Your username must be between 3 and 12 characters!', action: 'keyup, blur', rule: 'length=3,12' }, { input: '#realNameInput', message: 'Real Name is required!', action: 'keyup, blur', rule: 'required' }, { input: '#realNameInput', message: 'Your real name must contain only letters!', action: 'keyup', rule: 'notNumber' }, { input: '#realNameInput', message: 'Your real name must be between 3 and 12 characters!', action: 'keyup', rule: 'length=3,12' }, { input: '#birthInput', message: 'Your birth date must be between 1/1/1900 and 1/1/2012.', action: 'valuechanged', rule: function (input, commit) { var date = $('#birthInput').jqxDateTimeInput('value'); var result = date.getFullYear() >= 1900 && date.getFullYear() <= 2012; // call commit with false, when you are doing server validation and you want to display a validation error on this field. return result; } }, { input: '#passwordInput', message: 'Password is required!', action: 'keyup, blur', rule: 'required' }, { input: '#passwordInput', message: 'Your password must be between 4 and 12 characters!', action: 'keyup, blur', rule: 'length=4,12' }, { input: '#passwordConfirmInput', message: 'Password is required!', action: 'keyup, blur', rule: 'required' }, { input: '#passwordConfirmInput', message: 'Passwords doesn\'t match!', action: 'keyup, focus', rule: function (input, commit) { // call commit with false, when you are doing server validation and you want to display a validation error on this field. if (input.val() === $('#passwordInput').val()) { return true; } return false; } }, { input: '#emailInput', message: 'E-mail is required!', action: 'keyup, blur', rule: 'required' }, { input: '#emailInput', message: 'Invalid e-mail!', action: 'keyup', rule: 'email' }, { input: '#ssnInput', message: 'Invalid SSN!', action: 'valuechanged, blur', rule: 'ssn' }, { input: '#phoneInput', message: 'Invalid phone number!', action: 'valuechanged, blur', rule: 'phone' }, { input: '#zipInput', message: 'Invalid zip code!', action: 'valuechanged, blur', rule: 'zipCode' }, { input: '#acceptInput', message: 'You have to accept the terms', action: 'change', rule: 'required', position: 'right:0,0'}], theme: theme }); }); </script> <style type="text/css"> .text-input { height: 21px; width: 150px; } .register-table { margin-top: 10px; margin-bottom: 10px; } .register-table td, .register-table tr { margin: 0px; padding: 2px; border-spacing: 0px; border-collapse: collapse; font-family: Verdana; font-size: 12px; } h3 { display: inline-block; margin: 0px; } </style></head><body class='default'> <div id="register"> <div><h3>Register</h3></div> <div> <form id="testForm" action="./"> <table class="register-table"> <tr> <td>Username:</td> <td><input type="text" id="userInput" class="text-input" /></td> </tr> <tr> <td>Password:</td> <td><input type="password" id="passwordInput" class="text-input" /></td> </tr> <tr> <td>Confirm password:</td> <td><input type="password" id="passwordConfirmInput" class="text-input" /></td> </tr> <tr> <td>Real name:</td> <td><input type="text" id="realNameInput" class="text-input" /></td> </tr> <tr> <td>Birth date:</td> <td><div id="birthInput"></div></td> </tr> <tr> <td>E-mail:</td> <td><input type="text" id="emailInput" placeholder="someone@mail.com" class="text-input" /></td> </tr> <tr> <td>SSN:</td> <td><div id="ssnInput"></div></td> </tr> <tr> <td>Phone:</td> <td><div id="phoneInput"></div></td> </tr> <tr> <td>Zip code:</td> <td><div id="zipInput"></div></td> </tr> <tr> <td colspan="2" style="padding: 5px;"><div id="acceptInput" style="margin-left: 50px;">I accept terms</div></td> </tr> <tr> <td colspan="2" style="text-align: center;"><input type="button" value="Send" id="sendButton" /></td> </tr> </table> </form> </div> </div></body></html>
You can also define custom validation rules and specify whether the validation passes or fails. An example of such custom validation rule is implemented in the code above for the Birth Date field.
