jQuery UI Widgets Forums Editors DateTimeInput validate with required impossible?
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 4 months ago.
  • validate with required impossible? #14293
    UJanke
    if i try to validate a jqxdatetimeinput with a validator like this:
    rules: [
    { input: ‘#jqxdatetimeinput’, message: ‘Date is required!’, action: ‘valuechanged’, rule: ‘required’ }
    it never ever will validate sucessfull. Even when a correct date is inserted.
    Also the method xxxx.jqxValidator(‘validate’) don’t works.
    Any idears?
    Greetings
    Uwe
    validate with required impossible? #14295
    Hi Uwe,
    ‘required’ validation rule can be used for empty input fields. jqxDateTimeInput always has a value, so that rule cannot be used with that widget. In addition, your “action” is “valuechanged” so the rule will be tested after the jqxDateTimeInput’s value is changed.
    For validation, see: defaultfunctionality.htm.
    The demo demonstrates that the ‘validate’ method works, too.
