jQuery UI Widgets Forums Navigation NavigationBar, ToolBar, NavBar using navigationBar inside of jqxWindow
This topic contains 3 replies, has 2 voices, and was last updated by  edwardsmarkf 10 years, 10 months ago.
  • using navigationBar inside of jqxWindow #58626
    edwardsmarkf
    hello all –
    i am trying to incorporate the fantastic navigation widget inside of a window. it works great when initially loaded, but when reloaded it stops working:
    http://jsfiddle.net/edwardsmarkf/khxee0ee/
    any suggestions?
    thank you.
    example code below:
    var basicDemo = (function () {
    function _addEventListeners() { };
    function _createElements() { };
    function _createWindow() {
    $(‘#window’).jqxWindow({
    showCollapseButton: true, maxHeight: 400, maxWidth: 700, minHeight: 200, minWidth: 200, height: 300, width: 500,
    initContent: function () {
    $(‘#window’).jqxWindow(‘focus’);
    return {
    config: {
    dragArea: null
    init: function () {
    _createElements();
    _addEventListeners();
    _createWindow();
    //Initializing the demo
    basicDemo.init();
    navigationBar();
    function navigationBar() {
    $(‘div#windowContentEmbedded’).html( $(‘div#jqxNavigationBar’).html() );
    $(“div#windowContentEmbedded”).jqxNavigationBar({ width: 400, });
    <body class=’default’>
    <input type=”button” value=”replace original contents” onclick=’navigationBar();’ />
    <div id=”jqxWidget”>
    <div id=”window”>
    <div id=”windowHeader”>
    window header
    <div style=”overflow: hidden;” id=”windowContent”>
    <div id=’windowContentEmbedded’>
    this is marks test
    <div style=’display: none; visibility: hidden;’ id=’jqxNavigationBar’>
    <div>part one header</div>
    <div>part one body<br />more part one body</div>
    <div>part two header</div>
    <div>part two body<br />more part two body</div>
    <div>part three header</div>
    <div>part three body<br />more part three body</div>
    using navigationBar inside of jqxWindow #58636
    Hi edwardsmarkf,
    Sorry, but I don’t understand why you try to do this. You cannot call html() method and expect that the widget will work again when you replaced its entire HTML. If you want to recreate a widget for some unknown reason, the process is – destroy the widget, add its DOM structure again and create the widget.
    using navigationBar inside of jqxWindow #58651
    edwardsmarkf
    ok that worked – thank you very much.
    i am using a temporary widget in a variable and not trying to use any other widgets now to get it working:
    http://jsfiddle.net/edwardsmarkf/excwktpx/
    any suggestions or improvements are most welcome.
    using navigationBar inside of jqxWindow #58653
    edwardsmarkf
    working navigation bar inside of window:
