jQuery UI Widgets Forums Navigation Menu, Context Menu Using knockout for a sub-menu
This topic contains 1 reply, has 2 voices, and was last updated by  Vladimir 9 years, 10 months ago.
  • Using knockout for a sub-menu #75759
    DM
    Is it possible to have fixed content for a menu (using
    • tags) but to have it include a sub menu generated dynamically using json/knockout?
      If so, do you have an example?
    Using knockout for a sub-menu #75774
    Vladimir
    Hello alanfaux,
    Unfortunately we have no such demo.
    However what you can do is have a menu initialized by a dataAdapter connected to your json/knockout. Demo for json binding.
    And have logic inside one of the dataAdapter’s callback functions (for example loadComplete() callback function) that modifies your data so that has your fixed content along with your dynamic content. You may also need to reset the menu source in loadComplete if the databinding doesn’t update automatically.
    Vladimir
