jQuery UI Widgets Forums Grid Using jqxTrreGride with Row Details
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 9 years, 10 months ago.
  • Using jqxTrreGride with Row Details #74369
    uinfobrera
    How can I add an extra row for each tree-grid data record? These are the columns I’d like to have in the extra row
                     { text: 'Soggetto', dataField: 'Soggetto', width: 200 },
                      { text: 'LastName', dataField: 'Numero_Inventario', width: 200 },
                      { text: 'Luogo_ripresa', dataField: 'Luogo_ripresa', width: 120 },
    Here the jqxgrid I use:
     $("#jqxgrid").jqxGrid(
                    theme: 'ui-sunny',
                    //theme: 'fresh',
                    width: 1820,
                    groupable: true,
                    pageable: false,
                    //pageable: true,
                    height: 680,
                      { text: 'Unità archivistica ', datafield: 'Unità_archivistica_1', width: 280 },
    			   	  { text: '', datafield: 'Unità_archivistica_2', width: 200 },
                      { text: '', datafield: 'Unità_archivistica_3', width: 200 },
                      { text: 'Numero Inventario', datafield: 'Numero_inventario', width: 180 },
                      { text: 'Luogo Ripresa', datafield: 'Luogo_ripresa', width: 210 },
                      { text: 'Soggetto', datafield: 'Soggetto', width: 600 },
                    groups: ['Unità_archivistica_1', 'Unità_archivistica_2', 'Unità_archivistica_3', /*'Unità_archivistica_4','Unità_archivistica_5',*/'Soggetto', 'Luogo_ripresa', 'Numero_inventario' ]
                $("#expand").jqxButton({ theme: theme });
                $("#collapse").jqxButton({ theme: theme });
                $("#expandall").jqxButton({ theme: theme });
                $("#collapseall").jqxButton({ theme: theme });
                // expand group.
                $("#expand").on('click', function () {
                    var groupnum = parseInt($("#groupnum").val());
                    if (!isNaN(groupnum)) {
                        $("#jqxgrid").jqxGrid('expandgroup', groupnum);
                // collapse group.
                $("#collapse").on('click', function () {
                        $("#jqxgrid").jqxGrid('collapsegroup', groupnum);
                // expand all groups.
                $("#expandall").on('click', function () {
                    $("#jqxgrid").jqxGrid('expandallgroups');
                // collapse all groups.
                $("#collapseall").on('click', function () {
                    $("#jqxgrid").jqxGrid('collapseallgroups');
                // trigger expand and collapse events.
                $("#jqxgrid").on('groupexpand', function (event) {
                    var args = event.args;
                    $("#expandedgroup").text("Group: " + args.group + ", Level: " + args.level);
                $("#jqxgrid").on('groupcollapse', function (event) {
                    $("#collapsedgroup").text("Group: " + args.group + ", Level: " + args.level);
    Is it possible to regulate the row’s height of a jqxtreegrid?
    Thanks a lot in advance
    Using jqxTrreGride with Row Details #74372
    Hello uinfobrera,
    In your code you are using jqxGrid, not jqxTreeGrid. In jqxGrid, rows can be added with the method addrow (example) and rows’ height can be adjusted with the property rowsheight (example). We also have row details/nested grids functionality demos. jqxTreeGrid also has this functionality: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxtreegrid/javascript-tree-grid-row-details.htm?arctic.
