jQuery UI Widgets Forums Getting Started Using jqwidgets from JavaScript within extjs
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 6 years, 8 months ago.
  • Gwyn
    I have an odd scenario. I have an application built with Extjs Modern toolkit. Unfortunately Extjs don’t have a very sophisticated grid but the rest of the framework is very good.
    What I am trying to do is use the jqwidgets grid within the Extjs app.
    I’ve managed to get it working to some degree but a it’s a little bit bodgy having to use jQuery. I have to create a div within an Extjs component and then use jQuery to populate it once the Extjs component is rendered.
    And there must be something wrong because even though I set a height of the grid to 100%, when you inspect the element you find somehow it’s been given a fixed height of 400.
    Anyone got any suggestions as to how to do this neatly?
    To complicate further Extjs is being driven by a .Net back end sending instructions to the front-end via JSON and http.
    What I really want to do is:
    Create local dataset
    Create dataadapter
    Create grid
    Add grid to document.
    Any ideas or thoughts?
    Hi Gwyn,
    We do not have integration examples with ExtJS. The Grid’s height should be set by using the Grid’s height javascript property. It accepts number, px or percentage, like $(“#grid”).jqxGrid({ height: ‘100%’, ….other options });
    Peter
