jQuery UI Widgets › Forums › Grid › Up and down arrow keys do not work properly
Tagged: #jqwidgets-grid, grid, javascript grid, jquery grid
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 8 years, 1 month ago.
I am having a weird problem,
It appears that when I use the up and down arrow keys to vertically scroll the grid, they appear to stop working at some point when I go past the grid’s scroll into view, meaning that I need to manually use the vertical scroll bar to the right of grid to bring into focus the rows, then, only do the up and down arrow keys begin to work again.
Here is the grid’s settings:
$("#jqxgrid").jqxGrid( { width: '100%', height: 140, selectionmode: 'singlerow', autoshowfiltericon: true, filterable: true, sortable: true, source: dataAdapter, pageable: true, pagesize: 10, pagesizeoptions: ['5', '10', '25', '50', '100', '250', '500', '1000'], columnsresize: true, columns: [ { text: 'File Number', datafield: 'c0', width: 200 }, { text: 'Date Received', datafield: 'c1', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'Request Type', datafield: 'c2', width: 200 }, { text: 'Document Type', datafield: 'c3', width: 200 }, { text: 'Client Identity', datafield: 'c4', width: 200 }, { text: 'Status', datafield: 'c5', width: 200 }, { text: 'Action Required', datafield: 'c6', width: 200 }, { text: 'Reference Docs', datafield: 'c7', width: 200 }, { text: 'Assigned To', datafield: 'c8', width: 200 }, { text: 'Date Assigned', datafield: 'c9', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'Branch', datafield: 'c10', width: 200 }, { text: 'Division', datafield: 'c11', width: 200 }, { text: 'Other OPI', datafield: 'c12', width: 200 }, { text: 'DGO Due Date', datafield: 'c13', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'DO Due Date', datafield: 'c14', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'OPI Due Date', datafield: 'c15', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'DG Approval Date', datafield: 'c16', cellsformat: 'dd/MM/yyyy', width: 200 }, { text: 'DO Approval Date', datafield: 'c17', cellsformat: 'dd/MM/yyyy', width: 200 }, { text: 'OPI Approval Date', datafield: 'c18', cellsformat: 'dd/MM/yyyy', width: 200 }, { text: 'Summary', datafield: 'c19', width: 200, cellsrenderer: cellsrenderer }, { text: 'Key Topic', datafield: 'c20', width: 200 }, { text: 'Comments', datafield: 'c21', width: 200, cellsrenderer: cellsrenderer }, { text: 'E-mail', datafield: 'c22', width: 200 }, { text: 'Modified by', datafield: 'c23', width: 200 }, { text: 'Date Modified', datafield: 'c24', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 }, { text: 'Date Closed', datafield: 'c25', cellsformat: 'dd/MM/yyyy h:mm tt', width: 200 } ], });
See: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/defaultfunctionality.htm?light. we do not observe such behavior with this version.
