jQuery UI Widgets Forums Grid Unable to sort please help
This topic contains 1 reply, has 1 voice, and was last updated by  Blomotom 8 years ago.
  • Unable to sort please help #94697
    Blomotom
    <html lang="fr">
        <title id='Description'></title>
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.storage.js"></script>
    	//var getLocalization = function () {
            //  var localizationobj = {};
            //  localizationobj.currencysymbol = " €";
    	//	 localizationobj.currencysymbolposition = "after";
            //   localizationobj.decimalseparator = ".";
            //    localizationobj.thousandsseparator = ",";
            //     return localizationobj;
    		root: 'rows',
    			{ name: 'Number', type: 'float' },
                            { name: 'Name', type: 'string' },
    			{ name: 'Name2', type: 'string' },
    			{ name: 'Number2', type: 'float' },
    			{ name: 'Number3', type: 'float' }
    		sortcolumn: 'Number3',
    		sortdirection: 'asc',
    		cache: false,
                    url: 'datan.php',
    		filter: function() {
                    sort: function() {
                    beforeprocessing: function(data) {
                        if (data != null && data.length > 0) {
                            source.totalrecords = data[0].totalRecords;
                var filterChanged = false;
    				// remove the comment to debug
                    formatData: function(data) {
    					alert(JSON.stringify(data));
                        return data;
                   downloadComplete: function(data, status, xhr) {
                       if (!source.totalRecords) {
                           source.totalRecords = data.length;
                 loadError: function(xhr, status, error) {
                       throw new Error(error);
    		autowidth: true,
                    virtualmode: true,
                    rendergridrows: function(obj) {
                    return obj.data;
                     { text: 'Number', datafield: 'Number', width: 100},
    				 { text: 'Name', datafield: 'Name', width: 250},
    				 { text: 'Name2', datafield: 'Name2', width: 250} ,
    				 { text: 'Number2', datafield: 'Number2', width: 150},
    				 { text: 'Number3', datafield: 'Number3', width: 150}
    				// { text: 'Depense TTC', datafield: 'depense_ttc', width: 150, cellsformat: "c2", cellsalign: 'right'}
            <div id="jqxgrid"></div>
    Hello.
    I have a problem to sort data from json.
    When i clic on “sort” on columns on index.php, LOADING… but don’t sort values or name.
    Could you help me please.
    Best regards.
    Unable to sort please help #94709
    Blomotom
    solved, please delete this post
