jQuery UI Widgets Forums Angular Two way data binding is not working in jqxtreegrid.
This topic contains 3 replies, has 2 voices, and was last updated by  Martin 6 years, 8 months ago.
  • ErVishalM
    Hi, I am wondering if there is two way data binding in angular jqxtreegrid. I have created a editable jqxtreegrid from the ref. of jqxtreegrid but when i edit any column in jqxtreegrid then data is not changing in the assigned localdata variable.
    Martin
    Hello ErVishalM,
    There isn’t two way data binding for the source.
    You can update the localdata manually, for example on cellEndEdit event.
    Martin
    ErVishalM
    I think there is a confusion in my question.
    Here is my code –
    import { Component, ViewChild, OnInit, OnChanges, AfterViewInit } from '@angular/core';
    import { jqxTreeGridComponent } from 'jqwidgets-scripts/jqwidgets-ts/angular_jqxtreegrid';
    import { PageParam, SearchParam, SortParam, PagingParam } from '../shared/class/queryparam';
    import { MatSnackBarConfig } from '@angular/material';
    import { FormControl, Validators } from '@angular/forms';
    declare var $: any;
    @Component({
      selector: 'app-assetclass',
      templateUrl: './assetclass.component.html',
      styleUrls: ['./assetclass.component.css']
    export class AssetclassComponent implements OnInit, OnChanges, AfterViewInit {
      constructor() { }
      @ViewChild('TreeGrid') treeGrid: jqxTreeGridComponent;
      rowKey = null;
      // assetClassData: AssetClass[];
      assetClassData: any[] = [{
        'AssetClassID': 1, 'AssetClassName': 'Test', 'AssetClassCode': 'Test',
        'ParentAssetClassID': 0, 'InActive': false
      PageParams: PageParam[] = [];
      SearchParams: SearchParam[] = [];
      SortParams: SortParam;
      PagingParams: PagingParam;
      PageNumber = 1;
      columns: any[] = [
        { text: 'Name', dataField: 'AssetClassName', align: 'center', width: '70%' },
        { text: 'Code', dataField: 'AssetClassCode', align: 'right', cellsAlign: 'right', width: '20%' },
          text: 'Inactive', dataField: 'InActive', filtertype: 'checkedlist', align: 'center', cellsAlign: 'center', width: '10%'
          , columnType: 'template',
          createEditor: (row, cellvalue, editor, cellText, width, height) => {
            // construct the editor.
            editor.jqxCheckBox({ checked: false });
          initEditor: (row, cellvalue, editor, celltext, width, height) => {
            // set the editor's current value. The callback is called each time the editor is displayed.
            editor.jqxCheckBox('checked', cellvalue);
          getEditorValue: (row, cellvalue, editor) => {
            // return the editor's value.
            return editor.val();
      source: any =
          dataType: 'json',
          dataFields: [
            { name: 'AssetClassID', type: 'number' },
            { name: 'AssetClassName', type: 'string' },
            { name: 'ParentAssetClassID', type: 'number' },
            { name: 'AssetClassCode', type: 'string' },
            { name: 'InActive', type: 'number' }
          hierarchy:
            keyDataField: { name: 'AssetClassID' },
            parentDataField: { name: 'ParentAssetClassID' }
          localData: this.assetClassData,
          addRow: (rowID, rowData, position, parentID, commit) => {
            // call commit with parameter true if the synchronization with the server is successfull
            // you can pass additional argument to the commit callback which represents the new ID if it is generated from a DB.
            this.newRowID = rowID;
            commit(true);
          updateRow: (rowID, rowData, commit) => {
            commit(true);
          deleteRow: (rowID, commit) => {
            // synchronize with the server - send delete command
            commit(true);
      dataAdapter: any = new jqx.dataAdapter(this.source);
      newRowID = null;
      theme: String = '';
      buttonsObject: any = null;
      ngOnInit() {
      ngOnChanges() {
        // this.loadList();
      ngAfterViewInit(): void {
        this.treeGrid.createComponent();
      updateButtons(action: string, buttons: any): void {
        switch (action) {
          case 'Select':
            buttons.addButton.jqxButton({ disabled: false });
            buttons.deleteButton.jqxButton({ disabled: false });
            buttons.editButton.jqxButton({ disabled: false });
            buttons.cancelButton.jqxButton({ disabled: true });
            buttons.updateButton.jqxButton({ disabled: true });
            break;
          case 'Unselect':
            buttons.addButton.jqxButton({ disabled: true });
            buttons.deleteButton.jqxButton({ disabled: true });
            buttons.editButton.jqxButton({ disabled: true });
            break;
          case 'Edit':
            buttons.cancelButton.jqxButton({ disabled: false });
            buttons.updateButton.jqxButton({ disabled: false });
            break;
          case 'End Edit':
            console.log(this.assetClassData);
            break;
      renderToolbar = (toolBar) => {
        const toTheme = (className) => {
          if (this.theme === '') {
            return className;
          return className + ' ' + className + '-' + this.theme;
        // appends buttons to the status bar.
        const container: any = $('<div style="overflow: hidden; position: relative; height: 100%; width: 100%;"></div>');
        const buttonTemplate: any = '<div style="float: left; padding: 3px; margin: 2px;">' +
          '<div style="margin: 4px; width: 16px; height: 16px;"></div></div>';
        const addButton: any = $(buttonTemplate);
        const editButton: any = $(buttonTemplate);
        const deleteButton: any = $(buttonTemplate);
        const cancelButton: any = $(buttonTemplate);
        const updateButton: any = $(buttonTemplate);
        container.append(addButton);
        container.append(editButton);
        container.append(deleteButton);
        container.append(cancelButton);
        container.append(updateButton);
        toolBar.append(container);
        addButton.jqxButton({ cursor: 'pointer', enableDefault: false, disabled: true, height: 25, width: 25 });
        addButton.find('div:first').addClass(toTheme('jqx-icon-plus'));
        addButton.jqxTooltip({ position: 'bottom', content: 'Add' });
        editButton.jqxButton({ cursor: 'pointer', disabled: true, enableDefault: false, height: 25, width: 25 });
        editButton.find('div:first').addClass(toTheme('jqx-icon-edit'));
        editButton.jqxTooltip({ position: 'bottom', content: 'Edit' });
        deleteButton.jqxButton({ cursor: 'pointer', disabled: true, enableDefault: false, height: 25, width: 25 });
        deleteButton.find('div:first').addClass(toTheme('jqx-icon-delete'));
        deleteButton.jqxTooltip({ position: 'bottom', content: 'Delete' });
        updateButton.jqxButton({ cursor: 'pointer', disabled: true, enableDefault: false, height: 25, width: 25 });
        updateButton.find('div:first').addClass(toTheme('jqx-icon-save'));
        updateButton.jqxTooltip({ position: 'bottom', content: 'Save Changes' });
        cancelButton.jqxButton({ cursor: 'pointer', disabled: true, enableDefault: false, height: 25, width: 25 });
        cancelButton.find('div:first').addClass(toTheme('jqx-icon-cancel'));
        cancelButton.jqxTooltip({ position: 'bottom', content: 'Cancel' });
        this.buttonsObject = {
          addButton: addButton,
          editButton: editButton,
          deleteButton: deleteButton,
          cancelButton: cancelButton,
          updateButton: updateButton,
        addButton.click((event) => {
          if (!addButton.jqxButton('disabled')) {
            this.treeGrid.expandRow(this.rowKey);
            // add new empty row.
            this.treeGrid.addRow(null, {}, 'first', this.rowKey);
            // select the first row and clear the selection.
            this.treeGrid.clearSelection();
            this.treeGrid.selectRow(this.newRowID);
            // edit the new row.
            this.treeGrid.beginRowEdit(this.newRowID);
            this.updateButtons('add', this.buttonsObject);
          } else {
            this.treeGrid.addRow(null, {}, 'first', '0');
        cancelButton.click((event) => {
          if (!cancelButton.jqxButton('disabled')) {
            // cancel changes.
            this.treeGrid.endRowEdit(this.rowKey, true);
        updateButton.click((event) => {
          if (!updateButton.jqxButton('disabled')) {
            this.treeGrid.endRowEdit(this.rowKey, false);
        editButton.click(() => {
          if (!editButton.jqxButton('disabled')) {
            this.treeGrid.beginRowEdit(this.rowKey);
            this.updateButtons('edit', this.buttonsObject);
        deleteButton.click(() => {
          if (!deleteButton.jqxButton('disabled')) {
            const selection = this.treeGrid.getSelection();
            if (selection.length > 1) {
              for (let i = 0; i < selection.length; i++) {
                const key = this.treeGrid.getKey(selection[i]);
                this.treeGrid.deleteRow(key);
            } else {
              this.treeGrid.deleteRow(this.rowKey);
            this.updateButtons('delete', this.buttonsObject);
      rowSelect(event: any): void {
        const args = event.args;
        this.rowKey = args.key;
        this.updateButtons('Select', this.buttonsObject);
      rowUnselect(event: any): void {
        this.updateButtons('Unselect', this.buttonsObject);
      rowEndEdit(event: any): void {
        this.updateButtons('End Edit', this.buttonsObject);
      rowBeginEdit(event: any): void {
        this.updateButtons('Edit', this.buttonsObject);
      getWidth(): any {
        if (document.body.offsetWidth < 850) {
          return '90%';
        return 850;
    If i change Text value “Test” to “Testing” then in view it shows me “Testing” but in assetClassData data in still “Test”. I think that should auto update when i am changing any field binded from that. Otherwise how can i pick updated value? means Is there any other object in which data is stored as “Testing”?
    Martin
    Hello ErVishalM,
    The data binding is one-way so the assetClassData would not auto update.
    When you edit a cell you can pick the updated value from event.args parameter of the CellEndEdit event, as well as other information about the cell and row.
    You can take a look at this Demo.
    Martin
