jQuery UI Widgets Forums Grid two jqxGrid in same ng-controller – problem with settings.apply()
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 6 months ago.
  • badera
    Dear jqwidgets Support Team!
    I use jqWidgets together with AngularJS; therefore I use jqxGrid this way: <jqx-grid jqx-create=”gridSettings” jqx-settings=”gridSettings”> …
    This will add the apply(..) Method to $scope.gridSettings.
    However, I encountered problems having two concurrent jqx-grid widgets in one controller: none of the apply() methods of the settings object will work anymore – “undefined” is not a function is raised, if I like to call apply (before having a second grid, it worked well).
    Instead of using apply over the settings object, I use now e.g. jqx-instance=”mygrid” attribute to have $scope.mygrid accessible and then, I can successfully call $scope.mygrid.apply(..).
    Is this a bug? – I currently have no minimal example, since I have not yet the time to stripe all around to have it minimal – I assume that you will be able to quickly test this (e.g. by just making a master-details example for AngularJS) 🙂
    Thansk in advance for your help!
    best regards,
    badera
    Hi badera,
    Please, post your AngularJS questions in our Forum about AngularJS. In addition, please include a small html page which illustrates your issue.
