jQuery UI Widgets Forums Grid Trigger multi-sort only when pressing control
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 5 years, 5 months ago.
  • robf
    I’ve added multisort with sortmode: “many”, but users seem to get confused when they click on different columns for a single-sort only – since clicking on a new column heading immediately ADDS to the multisort. Is there a way to add a hot-key-select e.g. click heading while holding CTRL key adds to multisort?
    Any ideas?
    Rob
    Hello Rob,
    We do not have such an example but you could try it.
    I would like to suggest the handlekeyboardnavigation callback to handle the case when the CTRL” key is pressed.
    When it is pressed then set sortmode: "many" option.
    After that return the default state – sortmode: "one" option.
    https://www.jqwidgets.com
