jQuery UI Widgets Forums TreeGrid TreeGrid doesn't display my data .. Please Help !
This topic contains 1 reply, has 1 voice, and was last updated by  Sairam 10 years, 7 months ago.
  • Sairam
    I have a TreeGrid that should display a hierarchical data, while it displays the top parent node correctly the child records are not displayed. Please help. I have put in the code below.
    `<!DOCTYPE html>
    <html lang=”en”>
    <title id=’Description’>
    </title>
    <link rel=”stylesheet” href=”JQFiles/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”JQFiles/scripts/jquery-1.11.1.min.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxdatatable.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxtreegrid.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxinput.js”></script>
    <script type=”text/javascript” src=”JQFiles/jqwidgets/jqxslider.js”></script>
    <script type=”text/javascript” src=”JQFiles/scripts/demos.js”></script>
    <script type=”text/javascript” src=”JQFiles/demos/sampledata/generatedata.js”></script>
    var data = [
    “id”: “1”, “FB”: “Over Current”, “Group1”: “”, “Group2”: “”, “Group3”: “”, “Group4”: “”, “Group5”: “”, “Group6”: “”, “Group7”: “”, “Group8”: “”,
    “children”:
    “child”:
    { “id”: “2”, “FB”: “Status”, “Group1”: “1”, “Group2”: “2”, “Group3”: “3”, “Group4”: “4”, “Group5”: “5”, “Group6”: “6”, “Group7”: “7”, “Group8”: “8” },
    { “id”: “3”, “FB”: “Function”, “Group1”: “1”, “Group2”: “2”, “Group3”: “3”, “Group4”: “4”, “Group5”: “5”, “Group6”: “6”, “Group7”: “7”, “Group8”: “8” }
    “id”: “8”, “FB”: “Distance Setup”, “Group1”: “-“, “Group2”: “-“, “Group3”: “-“, “Group4”: “-“, “Group5”: “-“, “Group6”: “-“, “Group7”: “-“, “Group8”: “-“,
    “children”:
    “child”:
    { “id”: “9”, “FB”: “Status”, “Group1”: “1”, “Group2”: “2”, “Group3”: “3”, “Group4”: “4”, “Group5”: “5”, “Group6”: “6”, “Group7”: “7”, “Group8”: “8” }
    dataType: “json”,
    dataFields: [
    { name: “id”, type: “number” },
    { name: “FB”, type: “string” },
    { name: “Group1”, type: “string” },
    { name: “Group2”, type: “string” },
    { name: “Group3”, type: “string” },
    { name: “Group4”, type: “string” },
    { name: “Group5”, type: “string” },
    { name: “Group6”, type: “string” },
    { name: “Group7”, type: “string” },
    { name: “Group8”, type: “string” }
    hierarchy:
    root: “children>child”
    localData: data,
    loadComplete: function () {
    //alert(‘Load Complete’);
    $(“#treeGrid”).jqxTreeGrid(
    sortable: false,
    checkboxes: true,
    columnsReorder: true,
    width: 900,
    altrows: false,
    autoRowHeight: false,
    ready: function () {
    // Expand rows with ID = 1, 2 and 7
    //$(“#treeGrid”).jqxTreeGrid(‘expandRow’, 1);
    //$(“#treeGrid”).jqxTreeGrid(‘expandRow’, 2);
    //$(“#treeGrid”).jqxTreeGrid(‘expandRow’, 3);
    { text: ‘ID’, editable: false, dataField: ‘id’, pinned: true, width: 150 },
    { text: ‘Functional Block’, editable: false, pinned: true, dataField: ‘FB’, width: 200 },
    text: ‘Group 1’, dataField: ‘Group1’, width: 250, columnType: “template”,
    createEditor: function (row, cellvalue, editor, cellText, width, height) {
    // construct the editor.
    var source = [“Select”, “Enabled”, “Bisabled”, “Enabled VTS”,
    “Enabled CH Fail”];
    editor.jqxDropDownList({ autoDropDownHeight: true, source: source, width: ‘100%’, height: ‘100%’ });
    initEditor: function (row, cellvalue, editor, celltext, width, height) {
    // set the editor’s current value. The callback is called each time the editor is displayed.
    editor.jqxDropDownList(‘selectItem’, cellvalue);
    getEditorValue: function (row, cellvalue, editor) {
    // return the editor’s value.
    return editor.val();
    text: ‘Group 2’, dataField: ‘Group2’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 3’, dataField: ‘Group3’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 4’, dataField: ‘Group4’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 5’, dataField: ‘Group5’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 6’, dataField: ‘Group6’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 7’, dataField: ‘Group7’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    text: ‘Group 8’, dataField: ‘Group8’, width: 250, columnType: “template”,
    “Enabled CH Fail”];
    var listSource = [{ label: ‘Group 1’, value: ‘Group1’, checked: true }, { label: ‘Group 2’, value: ‘Group2’, checked: true },
    { label: ‘Group 3’, value: ‘Group3’, checked: true }, { label: ‘Group 4’, value: ‘Group4’, checked: true }, { label: ‘Group 5’, value: ‘Group5’, checked: true },
    { label: ‘Group 6’, value: ‘Group6’, checked: true }, { label: ‘Group 7’, value: ‘Group7’, checked: true }, { label: ‘Group 8’, value: ‘Group8’, checked: true}];
    $(“#jqxlistbox”).jqxListBox({ source: listSource, width: 300, height: 75, checkboxes: true });
    $(“#jqxlistbox”).on(‘checkChange’, function (event) {
    $(“#treeGrid”).jqxTreeGrid(‘beginUpdate’);
    if (event.args.checked) {
    $(“#treeGrid”).jqxTreeGrid(‘showColumn’, event.args.value);
    } else {
    $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, event.args.value);
    $(“#treeGrid”).jqxTreeGrid(‘endUpdate’);
    //This will hide the ID column on page load. The ID column can be used for programmatic purpose
    $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘id’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group4’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group5’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group6’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group7’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group8’);
    // $(“#treeGrid”).jqxTreeGrid(‘hideColumn’, ‘Group9′);
    <body class=’default’>
    <div id=’jqxWidget’>
    <table>
    <tr>
    <td>
    <div style=”float: left;” id=”jqxlistbox”></div>
    </td>
    </tr>
    <tr>
    <td>
    <div id=”treeGrid”></div>
    </td>
    </tr>
    </table>
    Sairam
    Solved it.
    I missed to mention the children in the dataFields section.
    Thanks anyway.
