jQuery UI Widgets › Forums › Grid › To have jqxgrid checkbox column in the column other than the first column.
Tagged: checkbox, checkbox column, checkbox selection, column, grid, jqxgrid, place, position, selectionmode
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 10 years, 4 months ago.
January 9, 2015 at 7:31 am To have jqxgrid checkbox column in the column other than the first column. #65165
I am developing a jqxgrid table having checkbox selection feature.I have a requirement where the checkbox selection column needs to be placed somewhere in the middle columns.By default
- selectionmode: ‘checkbox’
places this column as first column.
Is there any way where we can have this column other than the first column?
Thanks in advanceJanuary 9, 2015 at 7:54 am To have jqxgrid checkbox column in the column other than the first column. #65170Hello j2edev,
selectionmode: 'checkbox'
positions the checkbox selection column only at the beginning. If you wish to have the column elsewhere, you would have to implement a custom checkbox selection functionality, as shown in the following example:<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { // prepare the data var data = preparegriddata(200); var source = { localdata: data, datatype: "array", datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'available', type: 'bool' }, { name: 'quantity', type: 'number' } ], updaterow: function (rowid, rowdata, commit) { // synchronize with the server - send update command commit(true); } }; var dataAdapter = new $.jqx.dataAdapter(source); var columnCheckBox = null; var updatingCheckState = false; // initialize jqxGrid. Disable the built-in selection. $("#jqxgrid").jqxGrid( { source: dataAdapter, editable: true, enablehover: false, selectionmode: 'none', pageable: true, sortable: true, autoheight: true, columns: [ { text: 'First Name', editable: false, datafield: 'firstname', width: 90 }, { text: 'Last Name', editable: false, datafield: 'lastname', width: 90 }, { text: 'Product', editable: false, datafield: 'productname', width: 200 }, { text: 'Quantity', editable: false, datafield: 'quantity' }, { text: '', menu: false, sortable: false, datafield: 'available', columntype: 'checkbox', width: 40, renderer: function () { return '<div style="margin-left: 10px; margin-top: 5px;"></div>'; }, rendered: function (element) { $(element).jqxCheckBox({ width: 16, height: 16, animationShowDelay: 0, animationHideDelay: 0 }); columnCheckBox = $(element); $(element).on('change', function (event) { var checked = event.args.checked; var pageinfo = $("#jqxgrid").jqxGrid('getpaginginformation'); var pagenum = pageinfo.pagenum; var pagesize = pageinfo.pagesize; if (checked == null || updatingCheckState) return; $("#jqxgrid").jqxGrid('beginupdate'); // select all rows when the column's checkbox is checked. if (checked) { $("#jqxgrid").jqxGrid('selectallrows'); } // unselect all rows when the column's checkbox is checked. else if (checked == false) { $("#jqxgrid").jqxGrid('clearselection'); } // update cells values. var startrow = pagenum * pagesize; for (var i = startrow; i < startrow + pagesize; i++) { // The bound index represents the row's unique index. // Ex: If you have rows A, B and C with bound indexes 0, 1 and 2, afer sorting, the Grid will display C, B, A i.e the C's bound index will be 2, but its visible index will be 0. // The code below gets the bound index of the displayed row and updates the value of the row's available column. var boundindex = $("#jqxgrid").jqxGrid('getrowboundindex', i); $("#jqxgrid").jqxGrid('setcellvalue', boundindex, 'available', event.args.checked); } $("#jqxgrid").jqxGrid('endupdate'); }); return true; } } ] }); var updatePageState = function (pagenum) { var datainfo = $("#jqxgrid").jqxGrid('getdatainformation'); var pagenum = datainfo.paginginformation.pagenum; var pagesize = datainfo.paginginformation.pagesize; var startrow = pagenum * pagesize; // select the rows on the page. $("#jqxgrid").jqxGrid('beginupdate'); var checkedItemsCount = 0; for (var i = startrow; i < startrow + pagesize; i++) { var boundindex = $("#jqxgrid").jqxGrid('getrowboundindex', i); var value = $("#jqxgrid").jqxGrid('getcellvalue', boundindex, 'available'); if (value) checkedItemsCount++; if (value) { $("#jqxgrid").jqxGrid('selectrow', boundindex); } else { $("#jqxgrid").jqxGrid('unselectrow', boundindex); } } $("#jqxgrid").jqxGrid('endupdate'); if (checkedItemsCount == pagesize) { columnCheckBox.jqxCheckBox({ checked: true }); } else if (checkedItemsCount == 0) { columnCheckBox.jqxCheckBox({ checked: false }); } else { columnCheckBox.jqxCheckBox({ checked: null }); } } // update the selection after sort. $("#jqxgrid").on('sort', function (event) { updatePageState(); }); // update the selection after page change. $("#jqxgrid").on('pagechanged', function (event) { updatePageState(); }); // select or unselect rows when a checkbox is checked or unchecked. $("#jqxgrid").on('cellvaluechanged', function (event) { if (event.args.value) { $("#jqxgrid").jqxGrid('selectrow', event.args.rowindex); } else { $("#jqxgrid").jqxGrid('unselectrow', event.args.rowindex); } // update the state of the column's checkbox. When all checkboxes on the displayed page are checked, we need to check column's checkbox. We uncheck it, // when there are no checked checkboxes on the page and set it to intederminate state when there is at least one checkbox checked on the page. if (columnCheckBox) { var datainfo = $("#jqxgrid").jqxGrid('getdatainformation'); var pagesize = datainfo.paginginformation.pagesize; var pagenum = datainfo.paginginformation.pagenum; var selectedRows = $("#jqxgrid").jqxGrid('getselectedrowindexes'); var state = false; var count = 0; $.each(selectedRows, function () { if (pagenum * pagesize <= this && this < pagenum * pagesize + pagesize) { count++; } }); if (count != 0) state = null; if (count == pagesize) state = true; if (count == 0) state = false; updatingCheckState = true; $(columnCheckBox).jqxCheckBox({ checked: state }); updatingCheckState = false; } }); }); function preparegriddata(rowscount) { // prepare the data var data = new Array(); var firstNames = [ "Andrew", "Nancy", "Shelley", "Regina", "Yoshi", "Antoni", "Mayumi", "Ian", "Peter", "Lars", "Petra", "Martin", "Sven", "Elio", "Beate", "Cheryl", "Michael", "Guylene" ]; var lastNames = [ "Fuller", "Davolio", "Burke", "Murphy", "Nagase", "Saavedra", "Ohno", "Devling", "Wilson", "Peterson", "Winkler", "Bein", "Petersen", "Rossi", "Vileid", "Saylor", "Bjorn", "Nodier" ]; var productNames = [ "Black Tea", "Green Tea", "Caffe Espresso", "Doubleshot Espresso", "Caffe Latte", "White Chocolate Mocha", "Caramel Latte", "Caffe Americano", "Cappuccino", "Espresso Truffle", "Espresso con Panna", "Peppermint Mocha Twist" ]; for (var i = 0; i < rowscount; i++) { var row = {}; var productindex = Math.floor(Math.random() * productNames.length); var quantity = 1 + Math.round(Math.random() * 10); row["available"] = false; row["firstname"] = firstNames[Math.floor(Math.random() * firstNames.length)]; row["lastname"] = lastNames[Math.floor(Math.random() * lastNames.length)]; row["productname"] = productNames[productindex]; row["quantity"] = quantity; data[i] = row; } return data; } </script> </head> <body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> </div> </body> </html>
