jQuery UI Widgets › Forums › Grid › Time format does not work with 0's
This topic contains 7 replies, has 2 voices, and was last updated by Dimitar 11 years, 3 months ago.
I have a a grid that is displaying some times that are pulled from my database and when there is a valid time present, the formatting works correctly (it also works, shows nothing, when the time value is NULL). However, when the time value is all 0’s (0000-00-00 00:00:00), the formatting is not applied. Ive attached a picture to illustrate what exactly is going on.
here are the column and datafield definitions for the grid:
column:
{ text: "In", datafield: "time_in_1", columntype: 'datetimeinput', cellsformat: "hh:mm tt", width: 80 },
source/datafield:
{ name: 'time_in_1', type: 'date', format: "yyyy-MM-dd HH:mm:ss" },
Hello aoverton07,
Please share what is the format of your data source (XML, JSON, CSV, etc.) On our side, this scenario works, but the date is displayed as 12:00 AM.
http://www.jqwidgets.com/returned as string from mysql to php in format “0000-00-00 00:00:00”, echoed from php to javascript using json_encode();
recieved as string in javascript as “0000-00-00 00:00:00”;
Hi aoverton07,
Please share your source definition and grid initialization code.
http://www.jqwidgets.com/var detailSource = { url: '../phpDocs/someUrl.php', datatype: 'json', data: { action: 'timesheet_details', timesheetID: rowData.timesheet_id }, datafields: [ { name: 'timesheet_detail_id', type: 'string' }, { name: 'timesheet_id', type: 'string' }, { name: 'date', type: 'date' }, { name: 'time_in_1', type: 'date', format: "yyyy-MM-dd HH:mm:ss" }, { name: 'time_out_1', type: 'date', format: "yyyy-MM-dd HH:mm:ss" }, { name: 'time_in_2', type: 'date', format: "yyyy-MM-dd HH:mm:ss" }, { name: 'time_out_2', type: 'date', format: "yyyy-MM-dd HH:mm:ss" }, { name: 'st_hours', type: 'string' }, { name: 'ot_hours', type: 'string' }, { name: 'dt_hours', type: 'string' } ] }; var detailAdapter = new $.jqx.dataAdapter(detailSource); $("#timesheetDetailsGrid").jqxGrid({ theme: theme, source: detailAdapter, height: 203, width: 665, rowsheight: 25, columnsresize: true, columns: [ { text: "detailID", datafield: 'timesheet_detail_id', hidden: true }, { text: 'timesheetID', datafield: 'timesheet_id', hidden: true }, { text: "Date", datafield: "date", columntype: 'datetimeinput', cellsalign: 'right', cellsformat: "ddd - MM-dd-yyyy", width: 150 }, { text: "", width: 15 }, { text: "ST", datafield: "st_hours", width: 40 }, { text: "OT", datafield: "ot_hours", width: 40 }, { text: "DT", datafield: "dt_hours", width: 40 }, { text: "", width: 15 }, { text: "In", datafield: "time_in_1", columntype: 'datetimeinput', cellsformat: "hh:mm tt", width: 80 }, { text: "Out", datafield: "time_out_1", columntype: 'datetimeinput', cellsformat: "hh:mm tt", width: 80 }, { text: "", width: 15 }, { text: "In", datafield: "time_in_2", columntype: 'datetimeinput', cellsformat: "hh:mm tt", width: 80 }, { text: "Out", datafield: "time_out_2", columntype: 'datetimeinput', cellsformat: "hh:mm tt", width: 80 } ] });
Hello aoverton07,
We tested with the following example and there was no such issue:
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { var url = "../sampledata/dates.txt"; // prepare the data var source = { datatype: "json", datafields: [ { name: 'in', type: 'date', format: "yyyy-MM-dd HH:mm:ss" }, { name: 'out', type: 'date', format: "yyyy-MM-dd HH:mm:ss" } ], id: 'id', url: url }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid( { width: 850, autoheight: true, source: dataAdapter, columnsresize: true, columns: [ { text: 'In', datafield: 'in', width: 250, cellsformat: "ddd - MM-dd-yyyy" }, { text: 'Out', datafield: 'out', minwidth: 120, cellsformat: "ddd - MM-dd-yyyy" } ] }); }); </script> </head> <body class='default'> <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left;"> <div id="jqxgrid"> </div> </div> </body> </html>
And here is the contents of dates.txt:
[ { "in": "0000-00-00 00:00:00", "out": "2014-03-11 10:00:00" }, { "in": "2013-02-01 01:15:00", "out": "2015-08-11 10:00:00" } ]
Please make sure that you are using the latest version of jQWidgets (3.2.2) and that your PHP file returns a correct JSON. If nothing helps, you may use cellsrenderer to display a custom value (e.g. “No info”) when a cell’s value is “0000-00-00 00:00:00”.
http://www.jqwidgets.com/Hmmm that’s strange because I copy and pasted that code into one of your jsfiddle pages, and the problem persists:
Hi aoverton07,
The Date is Invalid and should be handled manually in your app, not by our component. Here is how to “mask” this value with a custom message:
var zeroRenderer = function (row, columnfield, value, defaulthtml, columnproperties) { if (value == "0000-00-00 00:00:00") { return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + ';">no date set</span>'; }; }; $("#jqxgrid").jqxGrid( { width: 850, autoheight: true, source: dataAdapter, columnsresize: true, columns: [ { text: 'In', datafield: 'in', width: 250, cellsformat: "ddd - MM-dd-yyyy", cellsrenderer: zeroRenderer }, { text: 'Out', datafield: 'out', minwidth: 120, cellsformat: "ddd - MM-dd-yyyy" } ] });
