jQuery UI Widgets Forums Angular Theme Builder Output Issues
This topic contains 4 replies, has 2 voices, and was last updated by  Gary 7 years, 5 months ago.
  • Theme Builder Output Issues #97735
    Gary
    I was looking at making a change to the “energy blue” theme and used the theme builder as directed.
    I got the following errors when running ng build with custom.css added to angular-cli.json.
    I added my CSS “custom.css” to jqwidgets-framework/jqwidgets/styles in node_modules.
    I’m running with the following versions:
      JQWIDGETS: 5.4.0
      Angular: 5.0.5
      Angular-cli: 1.5.5
    *** Error Output from NG BUILD ***
    WARNING in ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”sourceMap”:false}!./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:120:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:120:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at Object.emitWarning (C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\webpack\lib\NormalModule.js:117:16)
    at result.warnings.forEach (C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\postcss-loader\lib\index.js:149:49)
    at Array.forEach (<anonymous>)
    at postcss.process.then (C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\postcss-loader\lib\index.js:149:27)
    at <anonymous>
    @ ./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css 4:14-124
    @ multi ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.base.css ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.energyblue.css ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.darkblue.css ./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:138:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:138:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:156:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:156:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:210:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:210:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:211:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:211:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:222:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:222:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:237:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:237:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:238:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:238:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:249:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:249:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:264:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:264:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:265:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:265:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:276:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:276:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:290:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:290:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:305:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:305:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:320:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:320:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:39:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:39:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:67:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:67:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:85:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\custom.css:85:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    ERROR in ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”sourceMap”:false}!./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css
    Module not found: Error: Can’t resolve ‘./images/icon-bottom.png’ in ‘C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles’
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\package.json (relative path: ./jqwidgets/styles)
    Field ‘browser’ doesn’t contain a valid alias configuration
    after using description file: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\package.json (relative path: ./jqwidgets/styles)
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\package.json (relative path: ./jqwidgets/styles/images/icon-bottom.png)
    no extension
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png doesn’t exist
    .ts
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png.ts doesn’t exist
    .js
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png.js doesn’t exist
    as directory
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png]
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png.ts]
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-bottom.png.js]
    @ ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”sourceMap”:false}!./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css 6:16258-16293 6:16828-16863 6:17410-17445
    Module not found: Error: Can’t resolve ‘./images/icon-search.png’ in ‘C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles’
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\package.json (relative path: ./jqwidgets/styles/images/icon-search.png)
    no extension
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png doesn’t exist
    .ts
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png.ts doesn’t exist
    .js
    C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png.js doesn’t exist
    as directory
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png]
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png.ts]
    [C:\Users\Gary\WebstormProjects\GaryTest50\node_modules\jqwidgets-framework\jqwidgets\styles\images\icon-search.png.js]
    @ ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”sourceMap”:false}!./node_modules/jqwidgets-framework/jqwidgets/styles/custom.css 6:22932-22967
    Theme Builder Output Issues #97754
    Ivo Zhulev
    Hi Gary,
    Could you try placing the custom.css file in the assets folder and @import it in the styles.css file?
    Ivo
    Theme Builder Output Issues #97779
    Gary
    Hello Ivo…
    I placed custom.css in the src/assets directory and then add an import to styles.css and got the following errors below.
    I was looking at the error messages and see that we are getting two kinds. One is warnings and the other is errors.
    I have no idea what the warnings are saying but the error messages are looking for PNG files that are not in the JQWIDGETS IMAGE directory.
      C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png doesn’t exist
      C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png doesn’t exist
    *** ERROR OUTPUT ***
    WARNING in ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”plugins”:[null,null,null],”sourceMap”:false}!./src/assets/custom.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:120:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:120:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”sourceMap”:false}!./src/styles.css 3:10-173
    @ ./src/styles.css
    @ multi ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.base.css ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.energyblue.css ./node_modules/jqwidgets-framework/jqwidgets/styles/jqx.darkblue.css ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:138:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:138:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:156:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:156:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:210:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:210:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:211:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:211:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:222:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:222:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:237:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:237:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:238:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:238:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:249:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:249:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:264:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:264:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:265:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:265:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:276:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:276:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:290:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:290:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:305:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:305:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:320:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:320:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:39:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:39:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:67:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:67:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:85:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    NonErrorEmittedError: (Emitted value instead of an instance of Error) autoprefixer: C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\custom.css:85:5: Gradient has outdated direction syntax. New syntax is like to left instead of right.
    at <anonymous>
    @ ./src/styles.css
    ERROR in ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”plugins”:[null,null,null],”sourceMap”:false}!./src/assets/custom.css
    Module not found: Error: Can’t resolve ‘./images/icon-bottom.png’ in ‘C:\Users\Gary\WebstormProjects\GaryTest50\src\assets’
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\package.json (relative path: ./src/assets)
    after using description file: C:\Users\Gary\WebstormProjects\GaryTest50\package.json (relative path: ./src/assets)
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\package.json (relative path: ./src/assets/images/icon-bottom.png)
    no extension
    .ts
    C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png.ts doesn’t exist
    .js
    C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png.js doesn’t exist
    as directory
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png]
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png.ts]
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-bottom.png.js]
    @ ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”plugins”:[null,null,null],”sourceMap”:false}!./src/assets/custom.css 6:17500-17535 6:18232-18267 6:18976-19011
    @ ./src/styles.css
    Module not found: Error: Can’t resolve ‘./images/icon-search.png’ in ‘C:\Users\Gary\WebstormProjects\GaryTest50\src\assets’
    using description file: C:\Users\Gary\WebstormProjects\GaryTest50\package.json (relative path: ./src/assets/images/icon-search.png)
    no extension
    .ts
    C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png.ts doesn’t exist
    .js
    C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png.js doesn’t exist
    as directory
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png]
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png.ts]
    [C:\Users\Gary\WebstormProjects\GaryTest50\src\assets\images\icon-search.png.js]
    @ ./node_modules/css-loader?{“sourceMap”:false,”importLoaders”:1}!./node_modules/postcss-loader/lib?{“ident”:”postcss”,”plugins”:[null,null,null],”sourceMap”:false}!./src/assets/custom.css 6:25956-25991
    @ ./src/styles.css
    Theme Builder Output Issues #97789
    Ivo Zhulev
    Hi Gary,
    For now add this files manually(copy some other png and name it the needed way).
    We will add them soon.
    Thanks for the report!
    Ivo
    Theme Builder Output Issues #97801
    Gary
    Hello Ivo,
    I created the two PNG files and added to Images and the errors went away and I can use the Theme Builder.
    I still have the warnings but, got what I needed. This will give you time to look into the other issues around warnins.
    Gary
