jQuery UI Widgets › Forums › Grid › The problem use everpresentrow to add a column with columntype is dropdownlist
Tagged: #jqwidgets-grid, grid, javascript grid, jquery grid
This topic contains 5 replies, has 2 voices, and was last updated by Hristo 8 years, 3 months ago.
March 26, 2017 at 10:14 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92479
I have a column define like this:
text: ‘Action’,
datafield: ‘transtype’, cellsalign: ‘left’, align: ‘center’, width: 100 ,
displayfield: ‘transtype_name’ , columntype: ‘dropdownlist’ ,
createeditor: this.createTransTypesDropDownList ,createeverpresentrowwidget: (datafield, htmlElement, popup, addCallback) => {
var inputTag = $(“<div style=’border: none;’></div>”).appendTo(htmlElement);
this._everpresent_calfield.actionEdit = inputTag;
inputTag.jqxDropDownList({
popupZIndex: 999999, placeHolder:”Action:”, source:this.transtypeAdapter.records,
displayMember: ‘name’, valueMember: ‘id’, width: ‘100%’, height: 30, dropDownWidth: 220
});inputTag.change((event)=>{
var value = inputTag.val();
if (value) {
var transtype = this.transTypes.find(e=>e.id==value);
console.log(transtype: ${JSON.stringify(transtype)}
});$(document).on(‘keydown.transtype’, (event)=>{
if (event.keyCode === 27) {
if (event.target === inputTag[0])
var e = ”;
//this.myGrid.showeverpresentrow(false);
} else if (event.keyCode === 13) {
if (event.target === inputTag[0]) {
console.log(action catch Enter key pressed
addCallback();
} else if ($(event.target).ischildof(inputTag)) {
console.log(action catch Enter key pressed in the child element.
addCallback();
});return inputTag;
geteverpresentrowwidgetvalue: (datafield, htmlElement)=>{
var selectedItem = htmlElement.jqxDropDownList(‘getSelectedItem’);
if (!selectedItem)
return ”;
var value = selectedItem.value;
return value;
validateeverpresentrowwidgetvalue: (datafield, value, rowValues)=>{
if (!value)
return false;
return true;
}Add new row looks is successful.
But when I update the lastest new rows, in the updaterow callback, I found the rowid alwasy is 0, so when commit this update with true,
one row disappear
because they have same rowid.March 27, 2017 at 1:43 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92502Hello royer,
Could you provide us a whole example for better analyze?
Hristo HristovjQWidgets team
http://www.jqwidgets.comMarch 27, 2017 at 7:04 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92512Hi, Hristo,
I build a example . I use angular-cli Init a angular2 app.
after add two rows, then click the latest row to into edit mode, then press escape to quit edit mode,
the first add row disappear, and the left row can not into edit mode.the app.component.ts :
/// <reference path="../../node_modules/jqwidgets-framework/jqwidgets-ts/jqwidgets.d.ts" /> import { Component, ViewChild, AfterViewInit } from '@angular/core'; import { jqxGridComponent } from 'jqwidgets-framework/jqwidgets-ts/angular_jqxgrid'; interface StockTransation { id: number, date: Date, action: number, symbol: string, ammount: number } @Component({ selector: 'app-root', templateUrl: './app.component.html', styleUrls: ['./app.component.css'] }) export class AppComponent implements AfterViewInit { title = 'app works!'; rowid: any = null; @ViewChild('gridReference') myGrid: jqxGridComponent; actions: any = [ {id: 1, name: 'buy'}, {id: 2, name: 'sell'}, {id: 3, name: 'deposit'}, {id: 4, name: 'withdraw'}, {id: 5, name: 'dividend'}, {id: 6, name: 'buy to close'}, {id: 7, name: 'sell to open'} ]; transations: StockTransation[] = [ {id:1, date: new Date(2017,1,1), action: 1, symbol: 'AAPL', ammount: 1000.00} ]; ActionSource = { datatype: "array", datafields: [ { name: 'id', type: 'number' }, { name: 'name', type: 'string' } ], localdata: this.actions } ActionAdapter = new $.jqx.dataAdapter(this.ActionSource, {autoBind: true}); _addrow = (rowid, rowdata, position, commit)=> { let Action = this.actions.find(e=>{return e.id == rowdata.action}); rowdata.action_name = Action.name; commit(true); } _updaterow = (rowid, newdata, commit) => { this.rowid = rowid; commit(true); } dataSource = { datatype: 'array', datafields: [ { name: 'id', type: 'int' }, { name: 'date', type: 'date', format: 'yyy-MM-dd' }, { name: 'action', type: 'int' }, { name: 'action_name', value: 'action', values: { source: this.ActionAdapter.records, value: 'id', name: 'name'}}, { name: 'symbol', type: 'string'}, { name: 'ammount', type: 'float'} ], id: 'id', localdata: this.transations, addrow: this._addrow, updaterow: this._updaterow } dataAdapter = new $.jqx.dataAdapter(this.dataSource); settings: jqwidgets.GridOptions = { width: '100%', source: this.dataAdapter, selectionmode: 'multiplerows', pageable: false, autoheight: true, sortable: true, enabletooltips: true, editable: true, editmode: 'selectedrow', showeverpresentrow: true, columns: [ { text: 'Date', datafield: 'date', cellsformat: 'yyyy-MM-dd', columntype: 'datetimeinput', width: 110}, { text: 'Action', datafield: 'action', displayfield: 'action_name', cellsalign: 'left', align: 'center', width: 100, columntype: 'dropdownlist', createeditor: (row, value, editor)=> { editor.jqxDropDownList({source: this.ActionAdapter, displayMember: 'name', valueMember: 'id'}) }, createeverpresentrowwidget: (datafield, htmlElement, popup, addCallback)=> { var inputTag = $("<div style='border: none;'></div>").appendTo(htmlElement); inputTag.jqxDropDownList({ popupZIndex: 999999, placeHolder:"Action:", source:this.ActionAdapter.records, displayMember: 'name', valueMember: 'id', width: '100%', height: 30, dropDownWidth: 130 }); $(document).on('keydown.action', (event)=>{ if(event.keyCode==13) { if (event.target === inputTag[0]) { addCallback(); } else if ($(event.target).ischildof(inputTag)) { addCallback(); } } }); return inputTag; }, geteverpresentrowwidgetvalue: (datafield, htmlElement)=>{ var selectedItem = htmlElement.jqxDropDownList('getSelectedItem'); if (!selectedItem) { return ''; } else { return selectedItem.value; } } }, { text: 'Symbol', datafield: 'symbol'}, { text: 'Ammount', datafield: 'ammount'} ] } ngAfterViewInit() { this.myGrid.createComponent(this.settings); } }
the app.component.html :
<h1> {{title}} </h1> <p>updaterow param: rowid = {{rowid}}</p> <jqxGrid #gridReference [auto-create]="false"> </jqxGrid>
the app.module.ts :
import { BrowserModule } from '@angular/platform-browser'; import { NgModule } from '@angular/core'; import { FormsModule } from '@angular/forms'; import { HttpModule } from '@angular/http'; import { jqxGridComponent } from 'jqwidgets-framework/jqwidgets-ts/angular_jqxgrid'; import { AppComponent } from './app.component'; @NgModule({ declarations: [ AppComponent, jqxGridComponent ], imports: [ BrowserModule, FormsModule, HttpModule ], providers: [], bootstrap: [AppComponent] }) export class AppModule { }
the angular-cli.json :
{ "project": { "version": "1.0.0-beta.28.3", "name": "jqxgrid" }, "apps": [ { "root": "src", "outDir": "dist", "assets": [ "assets", "favicon.ico" ], "index": "index.html", "main": "main.ts", "polyfills": "polyfills.ts", "test": "test.ts", "tsconfig": "tsconfig.json", "prefix": "app", "styles": [ "../node_modules/jqwidgets-framework/jqwidgets/styles/jqx.base.css", "styles.css" ], "scripts": [ "../node_modules/jquery/dist/jquery.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxcore.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxdata.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxinput.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxdatetimeinput.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxcalendar.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxscrollbar.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxbuttons.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxmenu.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxlistbox.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxdropdownlist.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxcombobox.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxcheckbox.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxdata.export.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxdraw.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxchart.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxchart.annotations.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxchart.api.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxchart.core.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxchart.rangeselector.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.selection.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.aggregates.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.columnsreorder.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.columnsresize.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.edit.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.export.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.filter.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.grouping.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.pager.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.sort.js", "../node_modules/jqwidgets-framework/jqwidgets/jqxgrid.storage.js", "../node_modules/jqwidgets-framework/jqwidgets/globalization/globalize.js" ], "environments": { "source": "environments/environment.ts", "dev": "environments/environment.ts", "prod": "environments/environment.prod.ts" } } ], "e2e": { "protractor": { "config": "./protractor.conf.js" } }, "lint": [ { "files": "src/**/*.ts", "project": "src/tsconfig.json" }, { "files": "e2e/**/*.ts", "project": "e2e/tsconfig.json" } ], "test": { "karma": { "config": "./karma.conf.js" } }, "defaults": { "styleExt": "css", "prefixInterfaces": false, "inline": { "style": false, "template": false }, "spec": { "class": false, "component": true, "directive": true, "module": false, "pipe": true, "service": true } } }
March 28, 2017 at 12:07 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92529Hello royer,
Thank you for this example.
You could try to set some value for first (initial) row (set null or unique ID) – or{ id: 0, date: new Date(2017, 1, 1), action: 1, symbol: 'AAPL', ammount: 1000.00 }
It seems to work fine on that way.Best Regards,
http://www.jqwidgets.comMarch 28, 2017 at 4:06 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92545Hi, Hristo
Thank you for your replay, but I couldn’t understand what you mean ‘to set some value for first row‘?my problem is when use everpresentrow add two new rows, and then try to edit these new rows, there must have some bug.
if you mean just edit the first (initial) row, it’s not my point.
March 29, 2017 at 1:19 pm The problem use everpresentrow to add a column with columntype is dropdownlist #92565Hello royer,
I tested your example and while the set ID was “{id:1, date: new Date(2017,1,1)…”, when I change the id to 0 (or with null) it start to works normal.
Because when adding a new row, it is with “id: 1” and in that moment appears two rows with the same ID and this is incompatible.Best Regards,
