jQuery UI Widgets Forums Angular Template parse errors: jqxKanban' is not a known element:
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 6 years, 6 months ago.
  • michaelzhu288
    I got bellow message when trying to use the Kanban component.
    Would you please help check asap.
    ERROR Error: Uncaught (in promise): Error: Template parse errors:
    ‘jqxKanban’ is not a known element:
    1. If ‘jqxKanban’ is an Angular component, then verify that it is part of this module.
    2. To allow any element add ‘NO_ERRORS_SCHEMA’ to the ‘@NgModule.schemas’ of this component. (”
    app.module.ts
    import { BrowserModule } from ‘@angular/platform-browser’;
    import { NgModule } from ‘@angular/core’;
    import { ThemeComponent } from ‘./theme/theme.component’;
    import { LayoutModule } from ‘./theme/layouts/layout.module’;
    import { BrowserAnimationsModule } from “@angular/platform-browser/animations”;
    import { AppRoutingModule } from ‘./app-routing.module’;
    import { AppComponent } from ‘./app.component’;
    import { ScriptLoaderService } from “./_services/script-loader.service”;
    import { ThemeRoutingModule } from “./theme/theme-routing.module”;
    import { AuthModule } from “./auth/auth.module”;
    import {NgbActiveModal, NgbModule} from ‘@ng-bootstrap/ng-bootstrap’;
    import {HttpClientModule } from “@angular/common/http”;
    import {FormBuilder, FormsModule, ReactiveFormsModule } from “@angular/forms”;
    import {LocationStrategy, PathLocationStrategy} from “@angular/common”;
    import { jqxKanbanComponent } from ‘jqwidgets-scripts/jqwidgets-ts/angular_jqxkanban’;
    @NgModule({
    declarations: [
    ThemeComponent,
    AppComponent,
    jqxKanbanComponent
    imports: [
    LayoutModule,
    BrowserModule,
    BrowserAnimationsModule,
    AppRoutingModule,
    ThemeRoutingModule,
    AuthModule,
    NgbModule.forRoot(),
    HttpClientModule,
    FormsModule
    providers: [{provide: LocationStrategy, useClass: PathLocationStrategy},ScriptLoaderService,FormBuilder,NgbActiveModal],
    bootstrap: [AppComponent]
    export class AppModule { }
    Component:
    import { Component, ViewChild } from ‘@angular/core’;
    @Component({
    selector: ‘app-root’,
    templateUrl: ‘./price-upload-component.html’
    export class PriceUploadingComponent {
    @ViewChild(‘myKanbanOne’) myKanbanOne: jqxKanbanComponent;
    @ViewChild(‘myKanbanTwo’) myKanbanTwo: jqxKanbanComponent;
    @ViewChild(‘myKanbanThree’) myKanbanThree: jqxKanbanComponent;
    fields: any =
    { name: ‘status’, map: ‘state’, type: ‘string’ },
    { name: ‘text’, map: ‘label’, type: ‘string’ },
    { name: ‘tags’, type: ‘string’ },
    { name: ‘color’, map: ‘hex’, type: ‘string’ },
    { name: ‘resourceId’, type: ‘number’ }
    getWidth() : any {
    if (document.body.offsetWidth < 850) {
    return ‘90%’;
    return 850;
    source: any =
    localData:
    { state: ‘new’, label: ‘Combine Orders’, tags: ‘orders, combine’, hex: ‘#5dc3f0’, resourceId: 3 },
    { state: ‘new’, label: ‘Change Billing Address’, tags: ‘billing’, hex: ‘#f19b60’, resourceId: 1 },
    { state: ‘new’, label: ‘One item added to the cart’, tags: ‘cart’, hex: ‘#5dc3f0’, resourceId: 3 },
    { state: ‘new’, label: ‘Edit Item Price’, tags: ‘price, edit’, hex: ‘#5dc3f0’, resourceId: 4 },
    { state: ‘new’, label: ‘Login 404 issue’, tags: ‘issue, login’, hex: ‘#6bbd49’ }
    dataType: ‘array’,
    dataFields: this.fields
    dataAdapter: any = new jqx.dataAdapter(this.source);
    source2: any =
    localData:
    { state: ‘ready’, label: ‘Logout issue’, tags: ‘logout, issue’, hex: ‘#5dc3f0’, resourceId: 7 },
    { state: ‘ready’, label: ‘Remember password issue’, tags: ‘password, issue’, hex: ‘#6bbd49’, resourceId: 8 },
    { state: ‘ready’, label: ‘Cart calculation issue’, tags: ‘cart, calculation’, hex: ‘#f19b60’, resourceId: 9 },
    { state: ‘ready’, label: ‘Remove topic issue’, tags: ‘topic, issue’, hex: ‘#6bbd49’ }
    dataType: ‘array’,
    dataAdapter2: any = new jqx.dataAdapter(this.source2);
    source3: any =
    localData:
    { state: ‘done’, label: ‘Delete orders’, tags: ‘orders, combine’, hex: ‘#f19b60’, resourceId: 4 },
    { state: ‘work’, label: ‘Add New Address’, tags: ‘address’, hex: ‘#6bbd49’, resourceId: 5 },
    { state: ‘new’, label: ‘Rename items’, tags: ‘rename’, hex: ‘#5dc3f0’, resourceId: 6 },
    { state: ‘work’, label: ‘Update cart’, tags: ‘cart, update’, hex: ‘#6bbd49’ }
    dataType: ‘array’,
    dataAdapter3: any = new jqx.dataAdapter(this.source3);
    resourcesAdapterFunc = (): any => {
    let resourcesSource =
    localData:
    { id: 0, name: ‘No name’, image: ‘https://www.jqwidgets.com/angular/jqwidgets/styles/images/common.png’, common: true },
    { id: 1, name: ‘Andrew Fuller’, image: ‘https://www.jqwidgets.com/angular/images/andrew.png’ },
    { id: 2, name: ‘Janet Leverling’, image: ‘https://www.jqwidgets.com/angular/images/janet.png’ },
    { id: 3, name: ‘Steven Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/steven.png’ },
    { id: 4, name: ‘Nancy Davolio’, image: ‘https://www.jqwidgets.com/angular/images/nancy.png’ },
    { id: 5, name: ‘Michael Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/Michael.png’ },
    { id: 6, name: ‘Margaret Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/margaret.png’ },
    { id: 7, name: ‘Robert Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/robert.png’ },
    { id: 8, name: ‘Laura Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/Laura.png’ },
    { id: 9, name: ‘Laura Buchanan’, image: ‘https://www.jqwidgets.com/angular/images/Anne.png’ }
    dataType: ‘array’,
    dataFields:
    { name: ‘id’, type: ‘number’ },
    { name: ‘name’, type: ‘string’ },
    { name: ‘image’, type: ‘string’ },
    { name: ‘common’, type: ‘boolean’ }
    let resourcesDataAdapter = new jqx.dataAdapter(resourcesSource);
    return resourcesDataAdapter;
    kanbanOneColumns: any[] =
    { text: ‘Backlog’, dataField: ‘new’, maxItems: 10 }
    kanbanOneColumnRenderer: any = (element: any, collapsedElement: any, column: any): void => {
    if (element[0]) {
    let headerStatus = element[0].getElementsByClassName(‘jqx-kanban-column-header-status’)[0];
    let columnItems = this.myKanbanOne.getColumnItems(column.dataField).length;
    headerStatus.innerHTML = ‘ (‘ + columnItems + ‘/’ + column.maxItems + ‘)’;
    kanbanTwoColumns: any[] =
    { text: ‘Ready’, dataField: ‘ready’, maxItems: 10 }
    kanbanTwoColumnRenderer: any = (element: any, collapsedElement: any, column: any): void => {
    if (element[0]) {
    let columnItems = this.myKanbanTwo.getColumnItems(column.dataField).length;
    kanbanThreeColumns: any[] =
    { text: ‘Backlog’, dataField: ‘new’, maxItems: 5 },
    { text: ‘In Progress’, dataField: ‘work’, maxItems: 5 },
    { text: ‘Done’, dataField: ‘done’, maxItems: 5 }
    kanbanThreeColumnRenderer: any = (element: any, collapsedElement: any, column: any): void => {
    if (element[0]) {
    let columnItems = this.myKanbanThree.getColumnItems(column.dataField).length;
    let collapsedHeaderStatus = collapsedElement[0].getElementsByClassName(‘jqx-kanban-column-header-status’)[0];
    collapsedHeaderStatus.innerHTML = ‘ (‘ + columnItems + ‘/’ + column.maxItems + ‘)’;
    mainSplitterPanels: any[] = [{ size: 250, min: 100 }, { min: 250 }];
    rightSplitterPanels: any[] = [{ min: 200, size: 350, collapsible: false }, { min: 200 }];
    And ComponentModule
    import {NgModule} from ‘@angular/core’;
    import {CommonModule} from ‘@angular/common’;
    import {RouterModule, Routes} from ‘@angular/router’;
    import {DefaultComponent} from “../../../default/default.component”;
    import {LayoutModule} from “../../../../layouts/layout.module”;
    import {DevExtremeModule} from “devextreme-angular”;
    import {PriceUploadingComponent} from “./price-uploading.component”;
    const routes: Routes = [
    path: “”,
    component: DefaultComponent,
    children: [
    path: “”,
    component: PriceUploadingComponent
    @NgModule({
    imports: [
    CommonModule, RouterModule.forChild(routes), LayoutModule, DevExtremeModule
    ], exports: [
    RouterModule
    ], declarations: [
    export class PriceUploadingModule {
    Martin
    Hello michaelzhu288,
    This error appears when the jqx component is not included in the module’s ‘declarations’.
    From the code that you have sent I see that you have it in app.module.ts declarations.
    Can you try adding it also in the ComponentModule?
    Also, have you added the jqxkanban.ts file in the tsconfig.json?
    Martin
