jQuery UI Widgets Forums Navigation Tabs Tabs with using iframe on IE10
This topic contains 2 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 1 month ago.
  • Tabs with using iframe on IE10 #54336
    nyorozo
    There seems to be an error in DropDownList when using ifame as contents of Tabs (see below).
    The same thing happens in page number selector and hierarchy colum header in Grid.
    <default.html>
    <html lang=”en”>
    <link href=”library/jqwidgets/styles/jqx.base.css” rel=”stylesheet” type=”text/css” />
    <script type=”text/javascript” src=”library/jquery/jquery-1.11.0.js”></script>
    <script type=”text/javascript” src=”library/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”library/jqwidgets/jqxtabs.js”></script>
    <style type=”text/css”>
    </style>
    $(function() {
    $(“#RMM_Flame_Tabs”).jqxTabs({
    width :990,
    height :567
    <body >
    <span>Title</span>
    <div id=’jqxWidget’>
    <div id=”RMM_Flame_Tabs”>
    • tab1
    • tab2
    <div>
    <iframe height=”300px” src=”tab1.html”></iframe>
    <div>
    <iframe height=”300px” src=”tab2.html”></iframe>
    <tab1.html>
    <html lang=”en”>
    <script type=”text/javascript” src=”library/jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”library/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”library/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”library/jqwidgets/jqxdropdownlist.js”></script>
    </style>
    $(function () {
    var roomList= [“All”, “Room1”, “Room2”, “Room3”, “Room4”];
    $(“#RE_Room”).jqxDropDownList({
    source : roomList,
    selectedIndex: 3,
    width: ‘150px’,
    height: ’25px’,
    placeHolder: ‘Select Room’,
    autoDropDownHeight: true
    <body id=”body” class=”contents” >
    <div>
    <span>Title1</span>
    <div id=”RE_Room”></div>
    <tab2.html>
    <html lang=”en”>
    </style>
    $(function () {
    source : roomList,
    selectedIndex: 3,
    width: ‘150px’,
    height: ’25px’,
    <div>
    <span>Title2</span>
    Tabs with using iframe on IE10 #54337
    nyorozo
    The error happens when select tabs which is not default.
    In the sample case, when selecting tabs the layout of contents of dropdownlist is broken.
    Tabs with using iframe on IE10 #54362
    Hi nyorozo,
    To learn how to use widgets within jqxTabs, see: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxtabs/integration.htm?arctic and follow the same pattern.
