This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 3 months ago.
  • Tabindex problems #51046
    nico
    I’ve seen that your tabindex strategy has some bugs.
    A framework has not to set tabindex without a developer need,
    and you cannot set many times the same tabindex number in page!
    This bug destroy any tabindex strategy built in page.
    An Example for jqWidget version 3.2.1
        <script type="text/ecmascript">
                var settings = {
                    theme: 'artic',
                    width: '100%',
                    expandMode: 'multiple',
                    expandedIndexes: [1]
                jQuery("#nav1").jqxNavigationBar(settings);
                jQuery("#nav2").jqxNavigationBar(settings);
            <input type="text" tabindex="1" id="text1"/>
            <input type="text" tabindex="2" id="text2"/>
            <div id="nav1">
                <div tabindex="3">Navigation Bar 1</div>
                <div>Lorem ipsum dolor sit amet.</div>
            <div id="nav2">
                <div tabindex="4">Navigation Bar 2</div>
    This code creates this situation:
    <input tabindex="1" /> // mine
    <input tabindex="2" /> // mine
    <div id="nav1">        // mine navigation bar div
        <div tabindex="1">       // Yours. I didn't request this tabindex
            <div tabindex="3" /> // mine title div
            <div />
        <div tabindex="2" />     // mine content div but you applied tabindex automatically!
    <div id="nav2">        // mine navigation bar div
            <div tabindex="4" /> // mine title div
            <div />
    What solution do you propose to this situation?
    Thank you
    Nico
    Tabindex problems #51048
    Hi Nico,
    Thank you for the information. Yes, we set the “tabindex” and we do it on purpose. Unfortunately, we cannot provide a solution which does not set “tabindex”. “tabindex” is required for keyboard navigation and is especially useful in case of DIV tags in Chrome & FF to get Focus.
    Tabindex problems #51050
    nico
    But if I want to setup my personal keyboard navigation to my page?
    Why do you setup the same tabindex priority many times?
    This is a completely wrong strategy.
    Please try to use my example page and give me some feedback.
    Do you really think this strategy is well formatted?
    Nico
    Tabindex problems #51051
    Hi Nico,
    That is how our widget works. I am sorry that it does not fit to your expectations.
