jQuery UI Widgets Forums Dialogs and Notifications Window Tab index problem in window
This topic contains 3 replies, has 3 voices, and was last updated by  Peter Stoev 11 years, 10 months ago.
  • Tab index problem in window #25391
    basumrinmoy
    I have a form with several input controls open in a window.From that window I have to open another window with some text input controls. But when I press tab key in 2nd window from 1st textbox control its focus to 1st control of 1st window and again.Tab index cannot go to 2nd textbox of 2nd window. I have use this
     $("#ChangeMobileSMSVerificationform").jqxWindow({keyboardNavigation: true, height: 300, width: 700, resizable: false, theme: theme, isModal: true, autoOpen: false, cancelButton: $("#Cancel"), modalOpacity: 0.30, initContent: function () {
    $('#ChangeMobileSMSVerificationform').jqxWindow('focus');
    Tab index problem in window #25461
    Hello basumrinmoy,
    We tested the following example for the reported issue using the latest version of jQWidgets (2.9.3). The focus correctly goes from the second window to the first and second text inputs in it.
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.summer.css" type="text/css" />
    <body>
    <div id='content'>
    $("#jqxwindow1").jqxWindow({ height: 300, width: 700, theme: 'summer' });
    $("#jqxwindow2").jqxWindow({ keyboardNavigation: true, height: 100, width: 500, resizable: false, theme: "summer", isModal: true, autoOpen: false, modalOpacity: 0.30, initContent: function () {
    $('#jqxwindow2').jqxWindow('focus');
    $("#open").click(function () {
    $("#jqxwindow2").jqxWindow("open");
    <div id='jqxwindow1'>
    <div>
    Header</div>
    <div>
    <input type="text" />
    <button id="open">
    Open window.</button>
    <div id='jqxwindow2'>
    <div>
    Header</div>
    <div>
    Tab index problem in window #25513
    basumrinmoy
    I follow same procedure as you show example . I am using 2.8.3 version. But problem remains.
    Tab index problem in window #25527
    Hi basumrinmoy,
    As Dimitar pointed out, the described behavior is not reproducible with version 2.9.3, not 2.8.3. I suggest you to consider moving to 2.9.3.
