jQuery UI Widgets Forums Grid Sum/Count Aggregate not working after filter
This topic contains 3 replies, has 2 voices, and was last updated by  assaf.frank123 12 years, 2 months ago.
  • assaf.frank123
    I filter the grid using any type of column filter and the sum and count aggregates are not shown correctly.
    I am using version 2.8.
    I have in my code the next section –
    $(“#jqxgrid”).on(“filter”, function (event)
    alert();
    $(‘#jqxgrid’).jqxGrid(‘refreshaggregates’);
    I have 2 grids – the first allows editing and the second does not:
    1. The first one always shows the first aggregated value. Filtering alone does not change the aggregates. The values are
    changed propely right after the filter I edit a certain cell. The method is not executed.
    2. The second non editable grid – the method is executed. after the alert the value of the aggregates is shown correct but this changes
    immidiatly once the code continues (this did so also without the method – after the filter took affect you can see the value is show properly
    for a split second and then changes quickly back to the original.
    Thanks.
    Please, post a sample which demonstrates your issue with jQWidgets 2.8.
    Below is a working sample:
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script>
    <script type="text/javascript" src="../../jqwidgets/globalization/globalize.js"></script>
    var theme = getDemoTheme();
    var data = generatedata(500);
    localdata: data,
    datafields:
    { name: 'name', type: 'string' },
    { name: 'date', type: 'date'},
    { name: 'quantity', type: 'number' }
    datatype: "array"
    $("#jqxgrid").jqxGrid(
    width: 685,
    showfilterrow: true,
    showaggregates: true,
    showstatusbar: true,
    selectionmode: 'multiplecellsextended',
    { text: 'Name', columntype: 'textbox', filtertype: 'textbox', filtercondition: 'starts_with', datafield: 'name', width: 115 },
    text: 'Product', filtertype: 'checkedlist', datafield: 'productname', width: 220
    { text: 'Available', datafield: 'available', columntype: 'checkbox', filtertype: 'bool', width: 67 },
    { text: 'Qty.', datafield: 'quantity', filtertype: 'number', cellsalign: 'right', aggregates: ['sum'] }
    $('#clearfilteringbutton').jqxButton({ height: 25, theme: theme });
    $('#clearfilteringbutton').click(function () {
    $("#jqxgrid").jqxGrid('clearfilters');
    <div id="jqxgrid">
    <input style="margin-top: 10px;" value="Remove Filter" id="clearfilteringbutton" type="button" />
    The Quantity column in the above code has aggregate. When a filter is applied, the aggregate is recalculated as expected.
    assaf.frank123
    Your example works good.
    Mine for some reason does not..
    I initialize the grid by JS data array (myData). The main code elements in the file –
    * imports –
    * JS init of grid
    var data = myData;
    localdata: data,
    datafields:
    { name: ‘id’, type: ‘string’},
    { name: ‘ind’, type: ‘string’},
    { name: ‘name’, type: ‘string’ },
    { name: ‘date’, type: ‘date’,format: ‘dd/MM/yyyy HH:mm’},
    { name: ‘phone’, type: ‘string’ },
    { name: ‘kw’, type: ‘string’ },
    { name: ‘lp’, type: ‘string’ },
    { name: ‘ad’, type: ‘string’ },
    { name: ‘deal’, type: ‘string’},
    { name: ‘cremarks’, type: ‘string’ },
    { name: ‘followupdate’, type: ‘date’, format: ‘dd/MM/yyyy’},
    { name: ‘remarks’, type: ‘string’ }
    datatype: “array”
    var linkrenderer = function (row, column, value) {
    if (value.indexOf(‘#’) != -1) {
    value = value.substring(0, value.indexOf(‘#’));
    var html = ‘<a target="_blank" href="MyServlet?vid=&pid=&tid=’+value+'”>’+value+”;
    return html;
    // new leads grid
    $(“#jqxgrid”).jqxGrid(
    height: 430,
    width: ‘100%’,
    selectionmode: ‘singlecell’,
    editable: false,
    showtoolbar: true,
    statusbarheight: 45,
    enabletooltips: true,
    var me = this;
    var container = $(“Leads sent to ”“);
    toolbar.append(container);
    { text: ‘Date’,pinned: true, align:’left’ ,datafield: ‘date’, filtertype: ‘date’, width: 150, cellsalign: ‘left’,
    cellsformat: ‘dd/MM/yyyy HH:mm’,aggregates: [‘count’]},
    { text: ‘Keyword’,pinned: true,align:’left’ , columntype: ‘textbox’, filtertype: ‘checkedlist’,cellsalign: ‘left’,datafield: ‘kw’,
    width: 120},
    { text: ‘Ad’,pinned: true,align:’left’ , columntype: ‘textbox’, filtertype: ‘checkedlist’,cellsalign: ‘left’,datafield: ‘ad’, width:
    120},
    { text: ‘Page’,pinned: true,align:’left’ , columntype: ‘textbox’, filtertype: ‘checkedlist’,cellsalign: ‘left’, datafield: ‘lp’,
    width:120,cellsrenderer: linkrenderer },
    { text: ‘Deal’,pinned: true,align:’left’ , columntype: ‘textbox’, filtertype: ‘checkedlist’,cellsalign: ‘left’, datafield: ‘deal’,
    width: 120},
    { text: ‘Deal Amount’,pinned: true, align:’left’ , datafield: ‘quantity’, filtertype: ‘number’, cellsalign: ‘left’,width:
    100 ,columntype:’numberinput’,aggregates: [‘sum’, ‘avg’]},
    { text: ‘Followup Date’, align:’left’ ,datafield: ‘followupdate’, filtertype: ‘date’, columntype: ‘datetimeinput’,width: 150,
    cellsalign: ‘left’, cellsformat: ‘dd/MM/yyyy’ },
    { text: ‘Account Remarks’,align:’left’ , columntype: ‘textbox’, filtertype: ‘textbox’,cellsalign: ‘left’, filtercondition: ‘contains’,
    datafield: ‘remarks’, width:200},
    { text: ‘Name’,align:’left’ , columntype: ‘textbox’, filtertype: ‘textbox’,cellsalign: ‘left’, filtercondition: ‘contains’,
    datafield: ‘name’, width: 150},
    { text: ‘Phone’,align:’left’ , columntype: ‘textbox’, filtertype: ‘textbox’,cellsalign: ‘left’, filtercondition: ‘contains’,
    datafield: ‘phone’, width: 150},
    { text: ‘Lead Remarks’,align:’left’ , columntype: ‘textbox’, filtertype: ‘textbox’,cellsalign: ‘left’, filtercondition: ‘contains’,
    datafield: ‘cremarks’, width: 200},
    { text: ‘id’, align:’right’ ,datafield: ‘id’}
    $(“#jqxgrid”).jqxGrid(‘hidecolumn’, ‘id’);
    I added the on “filter” function to try and solve the issue but also without it the problem stil occurs – upon change of filter the aggtegates changes for a split second and then jumps back to the original value (un filtered).
    Thanks.
    assaf.frank123
    I found the issue –
    for some reason my id column (that I hide later on)
    { text: ‘id’, datafield: ‘id’}
    caused the problem with the aggregates (I also see the the filter list open a slight slower when the id column is in the grid).
    Once I add all the attributes –
    { text: ‘id’, align:’left’ , columntype: ‘textbox’, filtertype: ‘textbox’,cellsalign: ‘left’, filtercondition: ‘contains’, datafield: ‘id’, width: 200}\\
    all works smoothly.
    Thanks.
