jQuery UI Widgets Forums Grid String reformatting issue.
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 7 years, 1 month ago.
  • String reformatting issue. #100264
    lightonb
    Hello.
    I am pulling in a sql query json with one of the fields:
    {name: ‘key_cut_description’, type: ‘string’},
    Then I am displaying below:
    {text: ‘Key Cut Description’, filtertype: ‘input’, datafield: ‘key_cut_description’, width: 300},
    The database value for this description is ’80E-13′, but it is displaying in the jqxgrid as ‘8e-12’
    This is one example.
    Any ideas what is going on, is this trying to convert something? It is driving me bonkers.
    Bryan
    String reformatting issue. #100277
    Martin
    Hello lightonb,
    Is the field type ‘string’ both in the database and in the source’s datafield type?
    If so, can you send your code with some of the data, so we can take a look?
    Thank you!
    Martin
