jQuery UI Widgets Forums Grid SQL connection with scroll bar
This topic contains 2 replies, has 2 voices, and was last updated by  Serdar 1 year ago.
  • SQL connection with scroll bar #134960
    Serdar
    Hi, I have a jqxgrid table with scrollbar enabled. How can I run a SQL query to the server after 50 rows during scrolling and get the next 50 rows, ie how can I run the ajax method. I saw the virtual scroll bar but I don’t understand what it is for, is it for sql connection? Can you please give an example. thanks
    SQL connection with scroll bar #134975
    admin
    Hi Serdar.
    Here’s a sample which you can use to achieve this:
        <link rel="stylesheet" href="../../jqwidgets/styles/jqx.classic.css" type="text/css" />
                var theme = 'classic';
    					 { name: 'ShippedDate', type: 'date'},
    					 { name: 'ShipName', type: 'string'},
    					 { name: 'ShipAddress', type: 'string'},
    					 { name: 'ShipCity', type: 'string'},
    					 { name: 'ShipCountry', type: 'string'}
    			    url: 'data.php',
    				cache: false,
    				filter: function()
    				sort: function()
    				root: 'Rows',
    					loadError: function(xhr, status, error)
    						alert(error);
                // initialize jqxGrid
                    source: dataadapter,
    				virtualmode: true,
    				showfilterrow: true,
    				rendergridrows: function(obj)
    					  return obj.data;
                          { text: 'Shipped Date', datafield: 'ShippedDate', cellsformat: 'yyyy-MM-dd', width: 200 },
                          { text: 'Ship Name', datafield: 'ShipName', width: 200 },
                          { text: 'Address', datafield: 'ShipAddress', width: 180 },
                          { text: 'City', datafield: 'ShipCity', width: 100 },
                          { text: 'Country', datafield: 'ShipCountry', width: 140 }
        <div id='jqxWidget'">
            <div id="jqxgrid"></div>
    hope this helps.
    https://www.jqwidgets.com/
    SQL connection with scroll bar #134980
    Serdar
    thank you so much
