jQuery UI Widgets Forums Grid spread sheet help
This topic contains 2 replies, has 2 voices, and was last updated by  ulao 12 years, 3 months ago.
  • spread sheet help #16491
    ulao
    I’m trying to load json data in the spread sheet example. It looks like it is loading the data but its blank? I was successful loading it in to a normal grid. When loading in to the spread sheet the rows number from 1 – 3 and this is correct as I have 3 rows of data in my json.
    Here is the spread sheet code I’m using.
    var theme = getDemoTheme();
    var url = “api/DB/”;
    // renderer for grid columns.
    var columnrenderer = function (value) {
    return ‘
    ‘ + value + ‘
    // renderer for grid cells.
    var numberrenderer = function (row, column, value) {
    return ‘
    ‘ + (1 + value) + ‘
    // create Grid datafields and columns arrays.
    var datafields = [];
    var columns = [];
    for (var i = 0; i < 26; i++) {
    var text = String.fromCharCode(65 + i);
    if (i == 0) {
    var cssclass = 'jqx-widget-header';
    if (theme != '') cssclass += ' jqx-widget-header-' + theme;
    columns[columns.length] = { pinned: true, exportable: false, text: "", columntype: 'number', cellclassname: cssclass, cellsrenderer: numberrenderer };
    datafields[datafields.length] = { name: text };
    columns[columns.length] = { text: text, datafield: text, width: 60, renderer: columnrenderer };
    unboundmode: true,
    totalrecords: 100,
    datafields: datafields,
    url: url
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    columns: columns
    Also I was wondering if there was a double click on cell 0,0 for select all, and click on row/col to select that row or col option?
    spread sheet help #16503
    Hi ulao,
    The Spreadsheet sample is a Grid in unbound mode which means that it is implemented without data binding. Setting cell values in unbound mode should be done either manually or via the “setcellvalue” method. If you need to bind the Grid to some data, do not use “unbound” mode.
    spread sheet help #16543
    ulao
    understood. I was able to make my data load by setting my column/datafield names to match my data. Is there a way to load data in anonymously?
    Here is what I had to do to get data to show.
    totalrecords: 3,
    { name: ‘Name’, type: ‘string’ },
    { name: ‘ID’, type: ‘number’ },
    url: url
    $(“#jqxgrid”).jqxGrid(
    width: 670,
    { text: ‘Name’, datafield: ‘Name’, width: 100 },
    { text: ‘ID’, datafield: ‘ID’, width: 100 },
