jQuery UI Widgets Forums Getting Started Splitter Problem
This topic contains 4 replies, has 2 voices, and was last updated by  Aemal 11 years, 8 months ago.
  • Splitter Problem #29349
    Aemal
    I want to have a layout design for my application (a full row for header, a full row for footer, a left panel for tree view and a center view for loading the contents in tabs).
    I need to have something like this: Click
    The header and footer should not have the collapse button. I made something like this in other framework and is really working fine.
    I have made something in jqWidgets, but can’t get it working as my desire, you need to collapse and expand the header once to get the display of bottom panel and as well I couldn’t fix the size of the header, footer and left panel to stick to a fixed size.
    Following is my code:
    <html lang=”en”>
    <title id=’Description’>Nested Splitters with jqxTabs. The sample demonstrates how to
    add the jqxTabs widget inside a Split Panel</title>
    <link rel=”stylesheet” href=”<?php echo base_url(); ?>assets/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/scripts/jquery-1.10.2.min.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxsplitter.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxtabs.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/scripts/gettheme.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxpanel.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxtree.js”></script>
    <script type=”text/javascript” src=”<?php echo base_url(); ?>assets/jqwidgets/jqxexpander.js”></script>
    $(‘#mainSplitter’).jqxSplitter({ height: ‘100%’, width: ‘100%’, orientation: ‘horizontal’, splitBarSize: 5, resizable: true, panels: [{ size: ’50px’ }, { size: ‘90%’ }] });
    $(‘#bottomSplitter’).jqxSplitter({ height: ‘100%’, width: ‘100%’, orientation: ‘horizontal’, panels: [{ size: ‘90%’  }, { size: ’50px’, collapsible: false  }] });
    $(‘#centerSplitter’).jqxSplitter({ height: ‘100%’, width: ‘100%’, orientation: ‘vertical’, panels: [{ size: ‘50%’, collapsible: false }, { size: ‘50%’ }] });
    //$(‘#centerTop’).jqxSplitter({ height: ‘100%’, width: ‘100%’, orientation: ‘horizontal’, panels: [{ size: ‘50%’, collapsible: true }, { size: ‘50%’ }] });
    <style type=”text/css”>
    html, body
    height: 100%;
    width: 100%;
    margin: 0px;
    padding: 0px;
    overflow: hidden;
    </style>
    <body>
    <div id=”mainSplitter”>
    <div>
    Top
    <div>
    <div id=”bottomSplitter”>
    <div>
    <div id=”centerSplitter”>
    <div>Left</div>
    <div>Center</div>
    <div>
    Footer
    Splitter Problem #29356
    Hi Aemal,
    Please, look at: http://www.jqwidgets.com/fluid-layout-with-fixed-header-and-footer/
    Splitter Problem #29362
    Aemal
    Dear Peter,
    Thanks a heap for your quick reply.
    The code mentioned in the post isn’t compatible with Fire Fox but with Google Chrome it shows fine.
    Splitter Problem #29364
    Hi Aemal,
    For FF, add -moz-box-sizing
    Splitter Problem #29368
    Aemal
    Thanks Peter for superb support!
