jQuery UI Widgets › Forums › General Discussions › Layouts › Docking › Splitter and Docking re-size problem
Tagged: docking, jqxDocking, jqxsplitter, resize, splitter, window
This topic contains 5 replies, has 2 voices, and was last updated by Dimitar 11 years, 3 months ago.
I have a setting of two splitters and in each part a docking with window panel in it:
| Splitter 1 | Splitter 2 |
| | win1 | | | win2 | | win2 | |
|Splitter 3 |
||win3 ||
+————————————————————-+When I re-size the top vertical splitter making splitter 1 wider this works fine the splitter and the windows in both splitter 1 and 2 resize OK, but when I resize again and reduce the size of splitter 1 the window(s) inside splitter 1 do not resize.
What I’m doing wrong?
This is the code I’m using:
<%@ page language=”java” contentType=”text/html; charset=utf-8″
pageEncoding=”utf-8″%>
<html lang=”en”>
<title id=’Description’>This example shows how to create a Grid from Array data.</title>
<link rel=”stylesheet” href=”jqwidgets/styles/jqx.base.css” type=”text/css” /><script type=”text/javascript” src=”Charts/FusionCharts.js”></script>
<script type=”text/javascript” src=”js/jquery-1.10.2.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxdata.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxexpander.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxmenu.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.selection.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.columnsresize.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.pager.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.sort.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxlistbox.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxdropdownlist.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxcheckbox.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxdockpanel.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxdocking.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxsplitter.js”></script>
<script type=”text/javascript” src=”jqwidgets/jqxwindow.js”></script>
<script type=”text/javascript” src=”js/gettheme.js”></script><script type=”text/javascript”>
$(document).ready(function () {var theme = getDemoTheme();
$(‘#mainsplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, orientation: ‘horizontal’,
panels: [{ size: 300, min: 300 }, {min: 200}] });
$(‘#topsplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, orientation: ‘vertical’,
panels: [{ size: 300, min: 250 }, {min: 450}] });
$(‘#leftdock’).jqxDocking( { orientation: ‘vertical’, width: ‘100%’, mode: ‘docked’});
$(‘#leftdock’).jqxDocking(‘hideAllCloseButtons’);
$(‘#leftdock’).jqxDocking(‘showAllCollapseButtons’);
$(‘#leftdock’).jqxDocking( ‘disableWindowResize’, ‘win1’);
$(‘#leftdock’).jqxDocking( ‘disableWindowResize’, ‘win2’);
$(‘#leftdock’).jqxDocking( ‘disableWindowResize’, ‘win3’);$(‘#rightdock’).jqxDocking( { orientation: ‘horizontal’, width: ‘100%’, mode: ‘docked’});
$(‘#rightdock’).jqxDocking(‘hideAllCloseButtons’);
$(‘#rightdock’).jqxDocking(‘showAllCollapseButtons’);
$(‘#rightdock’).jqxDocking( ‘disableWindowResize’, ‘win4’);
$(‘#rightdock’).jqxDocking( ‘disableWindowResize’, ‘win5’);
$(‘#rightdock’).jqxDocking( ‘disableWindowResize’, ‘win6’);$(‘#bottomdock’).jqxDocking( { orientation: ‘vertical’, width: ‘100%’, mode: ‘docked’});
$(‘#bottomdock’).jqxDocking({ disabled:true });
$(‘#bottomdock’).jqxDocking(‘hideAllCloseButtons’);
$(‘#bottomdock’).jqxDocking(‘showAllCollapseButtons’);
$(‘#bottomdock’).jqxDocking( ‘disableWindowResize’, ‘alerts’);});
function load() {
// prepare the datavar theme = getDemoTheme();
</script></head>
<body class=’default’>
<div id=”main”>
<div>
<button type=”button” onClick=”load();”>Click Me!</button>
<div id=”workframe” style=”width:100%; height:720px;”>
<div id=”mainsplitter”>
<div>
<div id=”topsplitter”>
<div style=”overflow: scroll;”>
<div id=”leftdock”>
<div>
<div id=”win1″ style=”height: 200px;”>
<div>
win1Checks
<div style=”overflow: hidden;”>
Test win1
<div id=”win2″ style=”height: 200px;”>
<div>
win2
Test win2
<div id=”win3″ style=”height: 200px;”>
<div>
win3
Test win3
<div id=”rightdock” >
<div style=”width: 300px;”>
<div id=”win4″ style=”width: 250px; height: 300px”>
<div>
win4
Test win4
<div id=”win5″ style=”width: 250px;”>
<div>
win5
Test win5
<div id=”win6″ style=”width: 250px;”>
<div>
win6
Test win6
<div>
<div id=”bottomdock”>
<div>
<div id=”alerts” style=”height: 100%;”>
<div>
Alerts Settings
Alerts
</div></div>
</html>This is still a problem.
Anyone know what the problem is?10x
Arikbd
Hello Arikbd,
We could not reproduce the reported issue. On our side, the windows in Splitter 1 resize in both cases. Please make sure you are using the latest version of jQWidgets (3.2.2) and try again.
Thanks. I have downloaded new version and I get the same result
This is after load
</iframe>” alt=”after load” />
This after re-size (wider)
</iframe>” alt=”resize (wider)” />
Still Ok. Now resize (nerrow)
</iframe>” alt=”nerrow” />
The window inside (win1) is not resized
I’m using the same code as above, I just downloaded version 3.2.2 and jquery version 1.11.1
Thanks.
Arikbd.
Sorry I had problem with the images
Hello arikbd,
We confirm the reported issue. It occurs in Google Chrome and Firefox but not in Internet Explorer. We will investigate it and if it is on our side, it will be fixed as soon as possible.
