jQuery UI Widgets Forums Grid sorting and paging breaks Grid
This topic contains 8 replies, has 2 voices, and was last updated by  webwired 11 years, 7 months ago.
  • sorting and paging breaks Grid #31360
    webwired
    Hello everyone, I got the Grid working, but then I wanted to add sorting and paging, I followed the examples, and when I view the data.php page by itself, it seems to be working fine, but on the Grid page, the Grid doesn’t load at all now…
    Here’s my data.php page code…
    <?php
    #Include the connect.php file
    include('connect.php');
    #Connect to the database
    //connection String
    $connect = mysql_connect($hostname, $username, $password)
    or die('Could not connect: ' . mysql_error());
    //select database
    mysql_select_db($database, $connect);
    //Select The database
    $bool = mysql_select_db($database, $connect);
    if ($bool === False){
    print "can't find $database";
    // get data and store in a json array
    $pagenum = $_GET['pagenum'];
    $pagesize = $_GET['pagesize'];
    $start = $pagenum * $pagesize;
    $query = "SELECT SQL_CALC_FOUND_ROWS * FROM OrderTickets WHERE ((ExaminerID = 0 OR ExaminerID = 2) AND OrderTicketCurrentStatus = 'Completed')";
    if (isset($_GET['sortdatafield']))
    $sortfield = $_GET['sortdatafield'];
    $sortorder = $_GET['sortorder'];
    $result = mysql_query($query) or die("SQL Error 1: " . mysql_error());
    $sql = "SELECT FOUND_ROWS() AS found_rows";
    $rows = mysql_query($sql);
    $rows = mysql_fetch_assoc($rows);
    $total_rows = $rows['found_rows'];
    if ($sortfield != NULL)
    if ($sortorder == "desc")
    $query = "SELECT OrderTickets.*, Agencies.AgencyName, Agents.AgentFirstName, Agents.AgentLastName, InsuranceCarriers.InsuranceCarrier
    FROM OrderTickets
    LEFT JOIN Agencies ON OrderTickets.AgencyID = Agencies.AgencyID
    LEFT JOIN Agents ON OrderTickets.AgentID = Agents.AgentID
    LEFT JOIN InsuranceCarriers ON OrderTickets.InsuranceCarrierID = InsuranceCarriers.InsuranceCarrierID
    WHERE ((ExaminerID = 0 OR ExaminerID = 2) AND OrderTicketCurrentStatus = 'Completed') ORDER BY" . " " . $sortfield . " DESC LIMIT $start, $pagesize";
    else if ($sortorder == "asc")
    FROM OrderTickets
    WHERE ((ExaminerID = 0 OR ExaminerID = 2) AND OrderTicketCurrentStatus = 'Completed') ORDER BY" . " " . $sortfield . " ASC LIMIT $start, $pagesize";
    else
    while ($row = mysql_fetch_array($result, MYSQL_ASSOC)) {
    $customers[] = array(
    'ClientName' => $row['OrderTicketFirstName'] .' '. $row['OrderTicketLastName'],
    'AgencyName' => $row['AgencyName'],
    'AgentName' => $row['AgentFirstName'] .' '. $row['AgentLastName'],
    'InsuranceCarrier' => $row['InsuranceCarrier'],
    'OrderTicketDateReceived' => $row['OrderTicketDateReceived'],
    'OrderTicketDateCompleted' => $row['OrderTicketDateCompleted']
    $data[] = array(
    'TotalRows' => $total_rows,
    'Rows' => $customers
    echo json_encode($data);
    Here’s my Grid page code…
    require 'includes/auth.php';
    $ExaminerID = $_SESSION['ExaminerID'];
    <html>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <link href="StyleSheet.css" rel="stylesheet" type="text/css" />
    <link rel="shortcut icon" href="images/favicon.ico" />
    <link rel="stylesheet" href="../jqwidgets-ver3.0.3/jqwidgets/styles/jqx.base.css" type="text/css" />
    <link rel="stylesheet" href="../jqwidgets-ver3.0.3/jqwidgets/styles/jqx.classic.css" type="text/css" />
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/scripts/jquery-1.10.2.min.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxgrid.pager.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxgrid.sort.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxdata.js"></script>
    var theme = 'classic';
    { name: 'ClientName', type: 'string'},
    { name: 'AgencyName', type: 'string'},
    { name: 'AgentName', type: 'string'},
    { name: 'InsuranceCarrier', type: 'string'},
    { name: 'OrderTicketDateReceived', type: 'date'},
    { name: 'OrderTicketDateCompleted', type: 'date'}
    url: 'data.php',
    cache: false,
    root: 'Rows',
    sort: function()
    $("jqxgrid").jqxGrid('updatebounddata', 'sort');
    $("#jqxgrid").jqxGrid(
    width: 900,
    virtualmode: true,
    rendergridrows: function()
    return dataadapter.records;
    { text: 'Client Name', datafield: 'ClientName', width: 150},
    { text: 'Agency', datafield: 'AgencyName', width: 200 },
    { text: 'Agent', datafield: 'AgentName', width: 150 },
    { text: 'Carrier', datafield: 'InsuranceCarrier', width: 200 },
    { text: 'Date Received', datafield: 'OrderTicketDateReceived', width: 100, cellsformat: 'MM-dd-yyyy' },
    { text: 'Date Completed', datafield: 'OrderTicketDateCompleted', width: 100, cellsformat: 'MM-dd-yyyy' }
    <title>Order Tickets</title>
    <div id="LogoHeader">
    <img src="images/logo.png" />
    <div id="Menu">
    <? include 'includes/menu.php'; ?>
    <div style="margin-left: auto; margin-right: auto; width: 900px;">
    <div id="jqxWidget">
    <div id="jqxgrid"></div>
    sorting and paging breaks Grid #31361
    Hi webwired,
    Here’s an online working sample with Server Paging, Sorting and Filtering – http://www.jqwidgets.com/jquery-widgets-demo/demos/php/serverfiltering_paging_and_sorting.htm?arctic. I suggest you to check it out and especially which JavaScript and CSS references you should include in your web page.
    sorting and paging breaks Grid #31362
    webwired
    Peter, I figured out how to add code to the forum page, does it still look like I’m missing something in regards to references?
    sorting and paging breaks Grid #31364
    Hi webwired,
    As far as I see, not all required files are included. I suggest you to look at the sample I posted and also to check your browser’s console.
    sorting and paging breaks Grid #31367
    webwired
    Peter, thank you… I got the data to display in the Grid, but the sorting and paging is having problems…
    The problem that I think the Sorting has, is because I have ‘ClientName’ put together from two different columns in the table, OrderTicketFirstName & OrderTicketLastName … I have the same thing going on for the ‘AgentName’, it is put together from AgentFirstName & AgentLastName … So that when it goes to sort, that column name doesn’t exist… I need some way to be able to fix that, any ideas?
    As far as the Paging goes, on the bottom when I click next or previous, it changes the records on the bottom row, but it doesn’t update the Grid with the new rows… Any ideas on that as well would be great?
    I left out Filtering from your example because I didn’t want to use it…
    Anyway, here is my data.php page code…
    <?php
    //connection String
    //select database
    $query = "SELECT SQL_CALC_FOUND_ROWS OrderTickets.*, Agencies.AgencyName, Agents.AgentFirstName, Agents.AgentLastName, InsuranceCarriers.InsuranceCarrier
    FROM OrderTickets
    FROM OrderTickets
    FROM OrderTickets
    else
    $data[] = array(
    And here is my Grid page code…
    <html>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxgrid.filter.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/jqwidgets/jqxdropdownlist.js"></script>
    <script type="text/javascript" src="../jqwidgets-ver3.0.3/scripts/gettheme.js"></script>
    url: 'data.php',
    cache: false,
    filter: function()
    sort: function()
    root: 'Rows',
    if (data != null)
    width: 900,
    virtualmode: true,
    rendergridrows: function(obj)
    return obj.data;
    <div id="Menu">
    sorting and paging breaks Grid #31368
    webwired
    I changed the source a bit… Here’s that new code…
    url: 'data.php',
    cache: false,
    root: 'Rows',
    sort: function()
    if (data != null)
    sorting and paging breaks Grid #31369
    webwired
    Ok, I figured out the paging… That’s all cleared up, I just have to figure out something for the sorting…
    sorting and paging breaks Grid #31370
    webwired
    Well, got the sorting figured out as well… just made this change inside of the data.php page code…
    if ($sortfield == "ClientName") {
    $sortfield = "OrderTicketLastName";
    if ($sortfield == "AgentName") {
    $sortfield = "AgentLastName";
    sorting and paging breaks Grid #31371
    webwired
    This post is resolved.
