jQuery UI Widgets Forums Scheduler showWeekends day format problem
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 4 years, 2 months ago.
  • showWeekends day format problem #114995
    jasperdd
    So we tried using the showWeekends parameter in our views in order to hide the weekends from showing up in our calendar.
    At first everything looked like it worked as we would expect:
    expected result
    However if we would skip to the next month, the names of the days are switched as if tuesday is the first day of the week:
    wrong result
    If we would go back to the initial month, the days stay like this.
    So the displayed dates are still correct but the name of the days are not (29 march = monday, not tuesday)
    Would you have any idea as to what might be the cause of this.
    Thanks in advance.
    EDIT:
    I can’t see the images myself in this post so if they are not displayed for you either please let me know. Thanks.
    showWeekends day format problem #115005
    Hello jasperdd,
    I would like to ask you for more details or one simple example that demonstrates your case.
    Meanwhile, I remember similar cases and I would like to suggest you try to change the days (the first day of the week) from the localization property.
    https://www.jqwidgets.com
