jQuery UI Widgets Forums General Discussions Show more demos
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years ago.
  • Show more demos #22300
    kc
    There needs to be more demos to simulate live production scenarios with minimal source code.  For example, there should be a dynamic modal window demo to simulate an alert.  The View Source should be only a couple of lines.
    Also, when I look at the View Source tab you should HIGHLIGHT the relevant code.
    As a potential customer evaluating your product it is a little frustrating to figure out how to create a simple modal window or how to set default values for a grid filtertype column.
    I am evaluating these jQuery suites for rapid development, hence rapid evaluation.
    Thanks…
    Show more demos #22309
    We will consider adding more demos in the future. We also already have a Demo with Modal Dialog.
    Here’s also a sample which dynamically adds a Modal Window.
    var window = $("<div><div>Title</div><div>Content</div></div>");
    window.appendTo(document.body);
    window.jqxWindow({ isModal: true });
