jQuery UI Widgets Forums Lists ComboBox Setting selectedIndex(-1) with Knockout does not deselect item
This topic contains 2 replies, has 2 voices, and was last updated by  Makla 12 years, 2 months ago.
  • Makla
    Setting selectedIndex(-1) doesn’t update input field. I think that it should automatically clear input when setting selectedIndex to -1.
    // View Model
    var listModel = function (items) {
    this.items = ko.observableArray(items);
    this.itemToAdd = ko.observable("");
    this.disabled = ko.observable(false);
    this.selectedIndex = ko.observable(1);
    // adds new item.
    this.addItem = function () {
    if (this.itemToAdd() != "") {
    this.items.push(this.itemToAdd()); // Adds the item. Writing to the "items" observableArray causes any associated UI to update.
    this.itemToAdd(""); // Clears the text box, because it's bound to the "itemToAdd" observable
    } .bind(this); // Ensure that "this" is always this view model
    // removes item.
    this.removeItem = function () {
    this.items.pop();
    // gets the selected index.
    this.getIndex = function () {
    alert("Selected Index: " + this.selectedIndex());
    // sets the selected index.
    this.setIndex = function () {
    this.selectedIndex(-1);
    $("#list").on('bindingComplete', function (event) {
    ko.applyBindings(new listModel(["Caffé Latte", "Cortado", "Espresso"]));
    Hi Makla,
    The Input field may contain data typed by the user, not the selected item so the field should not be cleared. Only the selection in the popup should be cleared.
