jQuery UI Widgets › Forums › General Discussions › Lists › ComboBox › Setting Initial Item When Using JSON Data
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 13 years, 1 month ago.
Hi
I’m loading my data from a JSON service using the jqxDataAdapter. I’m also using Knockout. I need to set an item upon loading the jqxComboBox. For example this will be the item the user has set in a previous session. I’m using a binding handler so I can setup the jqxComboBox:
ko.bindingHandlers['combo'] = { 'init': function (element, valueAccessor, allBindingsAccessor, viewModel) { var url = 'http://myurl.com/refData'; var source = { datatype: "json", datafields: [ { name: 'objectIdRef' }, { name: 'displayText' } ], id: "objectIdRef", url: url }; var dataAdapter = new $.jqx.dataAdapter(source); $(element).jqxComboBox( { width: "130px", height: "20px", dropDownWidth: 250, source: dataAdapter, displayMember: "displayText", valueMember: "objectIdRef", autocomplete: true }); //handle the field changing ko.utils.registerEventHandler(element, "change", function () { var observable = valueAccessor(); var v = $(element).jqxComboBox('getSelectedItem'); observable.valueId(v.value); observable.valueText(v.label); }); ko.utils.domNodeDisposal.addDisposeCallback(element, function () { $(element).jqxComboBox("destroy"); }); }, 'update': function (element, valueAccessor, allBindingsAccessor, viewModel) { // make sure the model is correctly initialized. var observable = ko.utils.unwrapObservable(valueAccessor()); } };
How can I do this? I’ve tried using code I found on the jqxDropDownList forum:
// get all items. var items = $(element).jqxComboBox("getItems"); // find the index by searching for an item with specific value. var indexToSelect = -1; var valueToFind = observable.valueId(); $.each(items, function (index) { if (this.value == valueToFind) { indexToSelect = index; return false; } }); $(element).jqxComboBox({ selectedIndex: indexToSelect });
However, this doesn’t work as getItems is returning an empty array. I assume this is because the items haven’t been loaded yet. I’m sure the answer is really simple and I’ve managed to do this for the jqxNumberInput but I can’t find any examples in the documentation of how to do this.
Hi sheepsteak,
To ensure that the dataAdapter is filled with records and your data is downloaded, you can use the jqxDataAdapter’s loadComplete callback function.
var dataAdapter = new $.jqx.dataAdapter(source, { loadComplete: function () { // your code here. } } );
