jQuery UI Widgets Forums Grid Setting height to header and columns
This topic contains 1 reply, has 2 voices, and was last updated by  Yavor Dashev 4 years, 3 months ago.
  • rsilva
    Hi
    I’m using angular to set dinamic header height and I cannot find which property I should use. So far I’ve tried with columnsheight on the template and on code but is not working. I’ve seen examples like this http://jsfiddle.net/jqwidgets/LspfG/ but is javascript not angular.
    Also, how can I get rows (not header) height to grow as content increases? Say I implement a multiline cell using cellrenderer and adding <br/> per each line?
    Regards
    Setting height to header and columns #115062
    Yavor Dashev
    Hi rsilva,
    I would recommend you to take a look at this demo:
    https://www.jqwidgets.com/angular/angular-grid/#https://www.jqwidgets.com/angular/angular-grid/angular-grid-computedcolumn.htm
    And here are some modifications of the demo on how to achieve similar functionality:
    //In your app.component.html file
    <jqxGrid
        [width]="getWidth()" [source]="dataAdapter" [columns]="columns"
        [editable]="true" [selectionmode]="'multiplecellsadvanced'"
        [columnsheight]="columnsheight"
        [rowsheight]="rowsHeight"
    </jqxGrid>
    And in the app.component.ts file:
    export class AppComponent {
       columnsheight: any = 50
       rowsHeight: any = 10
    //rest of the code
    Then in the cellsrenderer function in the ‘Total’ column:
                text: 'Total', editable: false, datafield: 'total',
                cellsrenderer: (index: number, datafield: string, value: any, defaultvalue: any, column: any, rowdata: any): string => {
                    let total = parseFloat(rowdata.price) * parseFloat(rowdata.quantity);
                    if(total < 15){
                      return '<div style="margin: 4px;" class="jqx-right-align">' + this.dataAdapter.formatNumber(total, 'c2') + '</div>';
                    }else {
                      this.rowsHeight = 50
                      return '<div style="margin: 4px;" class="jqx-right-align">' + this.dataAdapter.formatNumber(total, 'c2') + '<br> Cell value</div>';
    Yavor Dashev
