jQuery UI Widgets Forums Grid setcellvalue issue
This topic contains 4 replies, has 2 voices, and was last updated by  DavidSimmons 12 years ago.
  • setcellvalue issue #24033
    DavidSimmons
    When editing a field in my grid, “Notes” every thing works great and my test alert show updateColumn and updateValue value correct!
    var updateID = rowid;
    var updateColumn = args.datafield;
    var updateValue = args.value;
    alert(updateID+’ ‘+updateColumn+’ ‘+updateValue);//******* Test *****
    When editing the same field via the setcellvalue my test alert updateColumn and updateValue undefined!
    $(“#jqxGrid”).jqxGrid(‘setcellvalue’, 1, “Notes”, “New Value”);
    setcellvalue issue #24057
    The issue is not in the “setcellvalue” method. In the provided code the “args.datafield” is in the “updaterow” callback because there is no such parameter. There are 3 parameters which you can use in the “updaterow” and these are – rowID – row’s ID, rowData – the row’s data and commit – callback function which you need to call to either confirm or cancel the changes. “setcellvalue” works correctly.
    setcellvalue issue #24129
    DavidSimmons
    I am using a little different update than normal because I update each cell as changed, not the complete record. To do this I need the RecordID , columnName and columnValue which I get from the rowid, args.datafield and args.value. If you test this it works and I got this information from someone jqWidgets. If there is a better way let me know and I will change my approach.
    alert(updateID + ‘ ‘ + updateColumn + ‘ ‘ + updateValue);
    //$.getScript(“../javascript/gridPDOUpdateRow.js”, function(){ gridUpdateRow(jqxgrid, rowid, updateID, updateColumn, updateValue, valueSelected, rowdata, commit, source.url); });
    I guess the real question I should have asked is when using setcellvalue does it work the same as if you edited a cell’s value? If not is there a way to pass the commit=true or a way to have setcellvalue uses my a custom function?
    setcellvalue issue #24130
    “setcellvalue” is called by the Grid’s editor, too and the logic is the same. However, I should point again that args.datafield and args.value are not parameters of the “updaterow” and you shouldn’t base your logic on these.
    setcellvalue issue #24158
    DavidSimmons
    Can you tell me a supported way during the updaterow I can get the ColumnName that was changed. I do not want to update the complete record for one cell….
