jQuery UI Widgets Forums Grid second level groupping and paging error
This topic contains 3 replies, has 2 voices, and was last updated by  Stanislav 7 years, 6 months ago.
  • second level groupping and paging error #97984
    u.gutierrez
    We are having troubles using JqxGrid when paging and groupping are enabled. When the user makes a two level groupping, the grids renders the data wrong. Is it a bug or is there an additional configuration param that is missing?
    Error<br />fotos imanes<br />
    second level groupping and paging error #98023
    Stanislav
    Hello u.gutierrez,
    We didn’t find an issue with our tests.
    Can you please send us an example or a snippet, so we can test and reproduce the exact case.
    Stanislav
    second level groupping and paging error #98024
    u.gutierrez
    Here you are an extract of my code:
    var data = [];
    localdata: this.data,
    datafields:
    { name: ‘Edit’, type: ‘bool’ },
    { name: ‘Id’, type: ‘number’ },
    { name: ‘Code’, type: ‘string’ },
    { name: ‘Actions’, type: ‘string’ },
    { name: ‘PR_HineCode’, type: ‘number’ },
    { name: ‘Title’, type: ‘string’ },
    { name: ‘Sol_Status’, type: ‘string’ },
    { name: ‘MacroProjectTitle’, type: ‘string’ },
    { name: ‘MacroProjectUrl’, type: ‘string’ },
    { name: ‘OwnersNames’, type: ‘string’ },
    { name: ‘OwnersId’, type: ‘string’ },
    { name: ‘OwnersEmails’, type: ‘string’ },
    { name: ‘MembersNames’, type: ‘string’ },
    { name: ‘MembersId’, type: ‘string’ },
    { name: ‘MembersEmails’, type: ‘string’ },
    { name: ‘VisitorsNames’, type: ‘string’ },
    { name: ‘VisitorsId’, type: ‘string’ },
    { name: ‘VisitorsEmails’, type: ‘string’ },
    { name: ‘PR_StartDate’, type: ‘date’ },
    { name: ‘PR_EndDate’, type: ‘date’ },
    { name: ‘PR_Status’, type: ‘string’ },
    { name: ‘ProjectURL’, type: ‘string’ },
    { name: ‘PR_Size’, type: ‘string’ },
    { name: ‘Budget’, type: ‘number’ },
    { name: ‘PR_CostSaving’, type: ‘number’ },
    { name: ‘Risk’, type: ‘string’ },
    { name: ‘PR_Progress’, type: ‘number’ },
    { name: ‘PR_Criticality’, type: ‘string’ },
    { name: ‘PR_Priority’, type: ‘string’ },
    { name: ‘PR_ProjectType’, type: ‘string’ },
    { name: ‘PR_ExpectedEndDate’, type: ‘date’ },
    { name: ‘NotebookUrl’, type: ‘string’ },
    { name: ‘HineSitesFullText’, type: ‘string’ },
    { name: ‘PR_Department’, type: ‘string’ },
    { name: ‘Departments’, type: ‘string’ },
    { name: ‘Lean_x0020_targets’, type: ‘string’ },
    { name: ‘LeanTargets’, type: ‘string’ },
    { name: ‘CanEdit’, type: ‘bool’}
    datatype: “array”
    // Se inicializa el GRID
    $(“#jqxgrid”).jqxGrid(
    width: ‘3000’,
    autoloadstate: false,
    groupable: true,
    autoshowfiltericon: true,
    showdefaultloadelement: true,
    autoshowloadelement: false,
    columnsautoresize: true,
    pagesize: 50,
    enabletooltips: true,
    showgroupaggregates: true,
    showstatusbar: true,
    showaggregates: true,
    pagesizeoptions: [‘5′, ’10’, ’20’, ’50’, ‘100’],
    columnsreorder: true,
    statusbarheight: 25,
    ready: function () {
    $(‘.closeLink’).click(function (e) {
    e.preventDefault();
    { text: ”, dataField: ‘Actions’, width: 25, cellclassname: cellclassname, cellsrenderer: actionitemcellsrenderer },
    { text: ‘Hine Sites’, datafield: ‘HineSitesFullText’, width: 150, cellclassname: cellclassname },
    { text: ‘Title’, datafield: ‘Title’, width: 300, cellsrenderer: gotoitemcellsrenderer, cellclassname: cellclassname },
    { text: ‘Code’, datafield: ‘PR_HineCode’, width: 50, cellclassname: cellclassname, cellsformat: ‘d’ },
    { text: ‘Macro-project’, datafield: ‘MacroProjectTitle’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ”, datafield: ‘ProjectURL’, width: 30, cellsrenderer: gotoprojectsiteellsrenderer, cellclassname: cellclassname },
    { text: ”, datafield: ‘NotebookUrl’, width: 30, cellsrenderer: opennotebookcteellsrenderer, cellclassname: cellclassname },
    { text: ‘Owners’, datafield: ‘OwnersNames’, width: 200, cellclassname: cellclassname },
    { text: ‘Members’, datafield: ‘MembersNames’, width: 200, cellclassname: cellclassname },
    { text: ‘Visitors’, datafield: ‘VisitorsNames’, width: 200, cellclassname: cellclassname },
    { text: ‘Size’, datafield: ‘PR_Size’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Start Date’, datafield: ‘PR_StartDate’, width: 100, cellclassname: cellclassname, cellsformat: ‘dd/MM/yyyy’, filtertype: ‘date’ },
    { text: ‘Expected End Date’, datafield: ‘PR_ExpectedEndDate’, width: 100, cellclassname: cellexpectedenddateclassname, cellsformat: ‘dd/MM/yyyy’, filtertype: ‘date’ },
    { text: ‘End Date’, datafield: ‘PR_EndDate’, width: 100, cellclassname: cellclassname, cellsformat: ‘dd/MM/yyyy’, filtertype: ‘date’ },
    { text: ‘Project Status’, datafield: ‘PR_Status’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Progress %’, datafield: ‘PR_Progress’, width: 100, cellclassname: cellclassname, cellsformat:’p’ },
    { text: ‘Criticality’, datafield: ‘PR_Criticality’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Priority’, datafield: ‘PR_Priority’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Project Type’, datafield: ‘PR_ProjectType’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Budget’, datafield: ‘Budget’, width: 100, cellclassname: cellclassname, cellsformat: ‘F4’ },
    { text: ‘Cost Saving’, datafield: ‘PR_CostSaving’, width: 100, cellclassname: cellclassname, cellsformat: ‘F4’ },
    { text: ‘Risk’, datafield: ‘Risk’, width: 100, cellclassname: cellclassname, filtertype: ‘checkedlist’ },
    { text: ‘Departments’, datafield: ‘Departments’, width: 200, cellclassname: cellclassname },
    { text: ‘Lean Targets’, datafield: ‘LeanTargets’, width: 200, cellclassname: cellclassname }
    var contextMenu = $(“#ProjectContextMenu”).jqxMenu({ width: 200, autoOpenPopup: false, mode: ‘popup’ });
    $(“#jqxgrid”).on(‘contextmenu’, function () {
    return false;
    $(“#jqxgrid”).on(‘cellclick’, function (event) {
    var args = event.args;
    var rowIndex = args.rowindex;
    CanEdit = true;
    if (args.datafield == “Actions” && CanEdit) {
    var row = $(‘#jqxgrid’).jqxGrid(‘getrowdatabyid’, rowIndex);
    var source = [];
    if (row.CanEdit) {
    source.push({ label: ‘Edit’, value: row.Id });
    if (row.PR_Status.toUpperCase() === ‘NOT STARTED’) {
    source.push({ label: ‘Init’, value: row.Id });
    if (row.PR_Status.toUpperCase() === ‘IN PROGRESS’) {
    source.push({ label: ‘Advance’, value: row.Id });
    if (row.PR_Status.toUpperCase() === ‘NOT STARTED’ || row.PR_Status.toUpperCase() === ‘IN PROGRESS’) {
    source.push({ label: ‘Finish’, value: row.Id });
    source.push({ label: ‘Stand By’, value: row.Id });
    if (row.PR_Status.toUpperCase() === ‘STAND BY’ || row.PR_Status.toUpperCase() === ‘COMPLETED’) {
    source.push({ label: ‘Return’, value: row.Id });
    var contextMenu = $(“#ProjectContextMenu”).jqxMenu({ width: 200, source: source, autoOpenPopup: false, mode: ‘popup’ });
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft, parseInt(event.args.originalEvent.clientY) + 5 + scrollTop);
    return false;
    } else {
    $(“#ProjectContextMenu”).jqxMenu(‘close’)
    } else {
    $(“#ProjectContextMenu”).on(‘itemclick’, function (event) {
    var selectedOption = $.trim($(args).text());
    if (selectedOption == “Edit”) {
    var rowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    var row = $(‘#jqxgrid’).jqxGrid(‘getrowdatabyid’, rowindex);
    openEditItemDialog(row.Id);
    } else if (selectedOption == “Init”) {
    doActionOnTasks(‘Init’);
    } else if (selectedOption == “Finish”) {
    doActionOnTasks(‘Finish’);
    } else if (selectedOption == “Stand By”) {
    doActionOnTasks(‘Stand By’);
    } else if (selectedOption == “Return”) {
    doActionOnTasks(‘Return’);
    } else if (selectedOption == “Advance”) {
    $(“#inputPercentage”).val(row.PR_Progress.toString());
    $(“#hiddenPercentagePreve”).val(row.PR_Progress.toString());
    $(‘#WindowAdvance’).jqxWindow(‘open’);
    second level groupping and paging error #98128
    Stanislav
    Hello u.gutierrez,
    Your issue comes from the paging, if you disable it, you will see that it all works fine.
    You have to be very careful when using paging and grouping together.
    I hope this example is what you needed:
    Link
    Just group by First Name and Quantity, it will not duplicate the last row.
    Stanislav
