jQuery UI Widgets Forums Grid scrollbar problem
This topic contains 4 replies, has 3 voices, and was last updated by  Dimitar 9 years, 3 months ago.
  • scrollbar problem #14130
    I have a small grid in my small popup window
    the grid in my small windows may have some data that does not fit in the popup windw
    here is the code
    <div id="window" style="display:none">
    <div id="windowHeader">
    <span>
    Add more products
    </span>
    <div style="overflow: hidden;" id="windowContent">
    <div id="merchandiseGrid"></div>
    here is the window
    $('#window').jqxWindow({ showCollapseButton: true, maxHeight: 200, maxWidth: 350, minHeight: 200, minWidth: 350, height: 200, width: 350, theme:"darkblue" });
    here is the grid
    $("#merchandiseGrid").jqxGrid(
    width: 320,
    source: mDataAdapter,
    theme:"fresh",
    autoheight: false,
    enableellipsis:true,
    height:190,
    I want to get the grid with the scrollbar in the Fixed window.
    when i tried this, I can see the scrollbar but when i tried to scroll bar, i got error : “TypeError cannot read property top of undefined”
    scrollbar problem #14140
    Hello darkcloudbird,
    We were not able to reproduce the reported issue. Please try the following similar example and share your feedback. Also make sure you use the latest version of jQWidgets (as of now, it is 2.6.1).
    <title id='Description'>This demo illustrates the basic functionality of the Grid plugin.
    The jQWidgets Grid plugin offers rich support for interacting with data, including
    paging, grouping and sorting. </title>
    var theme = getTheme();
    var url = "../sampledata/products.xml";
    datatype: "xml",
    { name: 'ProductName', type: 'string' },
    { name: 'QuantityPerUnit', type: 'int' },
    { name: 'UnitPrice', type: 'float' },
    { name: 'UnitsInStock', type: 'float' },
    { name: 'Discontinued', type: 'bool' }
    root: "Products",
    record: "Product",
    url: url
    var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
    if (value < 20) {
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
    else {
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    altrows: true,
    enabletooltips: true,
    { text: 'Product Name', datafield: 'ProductName', width: 250 },
    { text: 'Quantity per Unit', datafield: 'QuantityPerUnit', width: 150 },
    { text: 'Unit Price', datafield: 'UnitPrice', cellsalign: 'right', cellsformat: 'c2', width: 70 },
    { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
    { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued', width: 100 },
    $("#jqxwindow ").jqxWindow({ showCollapseButton: true, maxHeight: 200, maxWidth: 350, minHeight: 200, minWidth: 350, height: 200, width: 350, autoOpen: false });
    $("#windowOpen").click(function () {
    $("#jqxwindow ").jqxWindow('open');
    <button id="windowOpen">
    Open window</button>
    <div id='jqxwindow'>
    <div>
    Header</div>
    <div>
    <div id="jqxgrid">
    scrollbar problem #14193
    thanks for the reply,
    it turns out that, if the both vertical and horizontal scrollbar appear, then the error, i made it wide enough so that the horizontal bar does not appear, then the error is gone.
    scrollbar problem #83707
    Natraj
    I have a strange behaviour in firefox. When i load a html file containing jqxgrid in a popup container and resize the columns, Scroll bar appears. But when i scroll table header and body moves differently. It works fine in chrome. Kindly provide me a solution.
    scrollbar problem #83729
    Hello Natraj,
    Could you, please, provide us with a jsEditor example reproducing the issue? Please make sure you are using the latest version of jQWidgets (4.1.1), too.
