jQuery UI Widgets › Forums › Angular › Save and Load Data of Filter
This topic contains 1 reply, has 2 voices, and was last updated by Martin 7 years ago.
I want to store filter data to database and when a particular user logged in I want to load that filtered data in jqxgrid with filter options selected in Angular 5.
import { jqxGridComponent } from 'jqwidgets-scripts/jqwidgets-ts/angular_jqxgrid'; @ViewChild('eventlogGrid') myGrid: jqxGridComponent; source: any = { datatype: 'json', datafields: [ { name: 'eventLogId', type: 'string' }, { name: 'eventType', type: 'string' }, { name: 'areaName', type: 'string' }, { name: 'locationName', type: 'string' }, { name: 'eventPriority', type: 'string' }, { name: 'locationCd', type: 'string' }, { name: 'description', type: 'string' }, { name: 'callerContactName', type: 'string' }, { name: 'calleeContactName', type: 'string' }, { name: 'gasControlContactName', type: 'string' }, { name: 'eventDateTimeStr', type: 'string' }, { name: 'eventGasDateTimeStr', type: 'string' }, ], id: 'eventLogId', url: webserviceurl+'/events' }; dataAdapter: any = new jqx.dataAdapter(this.source); cellsrenderer = (row: number, columnfield: string, value: string | number, defaulthtml: string, columnproperties: any, rowdata: any): string => { if (value < 20) { return <code><span style='margin: 4px; float:${columnproperties.cellsalign}; color: #ff0000;'>${value}</span></code>; } else { return <code><span style='margin: 4px; float:${columnproperties.cellsalign}; color: #008000;'>${value}</span></code>; } }; getColumnData(index) { var str_array = index.split(','); let percent_of_width = 100/str_array.length; var number_table_width = percent_of_width+'%'; let table_width = number_table_width.toString(); var column_data:any = [ { text: 'Event Log Id', datafield: 'eventLogId', width: table_width,hidden:true}, { text: 'Event Type', datafield: 'eventType', width: table_width,hidden:true}, { text: 'Area Name', datafield: 'areaName', width: table_width,hidden:true}, { text: 'Location Name', datafield: 'locationName', width: table_width,hidden:true}, { text: 'Priority', datafield: 'eventPriority', width: table_width,hidden:true}, { text: 'Location', datafield: 'locationCd', width: table_width,hidden:true}, { text: 'Description', datafield: 'description', width: table_width,hidden:true}, { text: 'Caller', datafield: 'callerContactName', width: table_width,hidden:true}, { text: 'Callee', datafield: 'calleeContactName', width: table_width,hidden:true}, { text: 'Controller', datafield: 'gasControlContactName', width:table_width,hidden:true}, { text: 'Event Date Time', datafield: 'eventDateTimeStr', width: table_width,hidden:true}, { text: 'Recorded Date Time', datafield: 'eventGasDateTimeStr', width: table_width,hidden:true}, ]; // columns hide show logic for events starts here for(var i=1;i<=12;i++) { if(str_array.includes(i.toString())) { column_data[i-1].hidden = false; } } // columns hide show logic for events ends here return column_data; } columns: any[] = this.column_data;
I have search for Jquery jqwidgets there is a function loadstateand savestate but I’m not able to find any example or code for Angular-5.
Can you please suggest me how I can store and fetch filter data.
Hello Bhavin,
You can use loadstate and savestate also in Angular5.
Here is some code examples for them from our Angular Grid API page:savestate:
import { Component, ViewChild, AfterViewInit } from "@angular/core"; @Component({ selector: "app-root", template: ' <jqxGrid #myGrid [width]="850" [source]="dataAdapter" [columns]="columns"> </jqxGrid> ' }) export class AppComponent implements AfterViewInit { @ViewChild('myGrid') myGrid: jqxGridComponent; ngAfterViewInit(): void { let value = this.myGrid.savestate(); } source: any = { localdata: [ ['Alfreds Futterkiste', 'Maria Anders', 'Sales Representative', 'Obere Str. 57', 'Berlin', 'Germany'], ['Ana Trujillo Emparedados y helados', 'Ana Trujillo', 'Owner', 'Avda. de la Constitucin 2222', 'Mxico D.F.', 'Mexico'], ['Antonio Moreno Taquera', 'Antonio Moreno', 'Owner', 'Mataderos 2312', 'Mxico D.F.', 'Mexico'] ], datafields: [ { name: 'CompanyName', type: 'string', map: '0' }, { name: 'ContactName', type: 'string', map: '1' }, { name: 'Title', type: 'string', map: '2' }, { name: 'Address', type: 'string', map: '3' }, { name: 'City', type: 'string', map: '4' }, { name: 'Country', type: 'string', map: '5' } ], datatype: 'array' }; dataAdapter: any = new jqx.dataAdapter(this.source); columns: any[] = [ { text: 'Company Name', datafield: 'CompanyName', width: 200 }, { text: 'Contact Name', datafield: 'ContactName', width: 150 }, { text: 'Contact Title', datafield: 'Title', width: 100 }, { text: 'Address', datafield: 'Address', width: 100 }, { text: 'City', datafield: 'City', width: 100 }, { text: 'Country', datafield: 'Country' } ]; }
loadstate:
import { Component, ViewChild, AfterViewInit } from "@angular/core"; @Component({ selector: "app-root", template: ' <jqxGrid #myGrid [width]="850" [source]="dataAdapter" [columns]="columns"> </jqxGrid> ' }) export class AppComponent implements AfterViewInit { @ViewChild('myGrid') myGrid: jqxGridComponent; ngAfterViewInit(): void { this.myGrid.loadstate(); } source: any = { localdata: [ ['Alfreds Futterkiste', 'Maria Anders', 'Sales Representative', 'Obere Str. 57', 'Berlin', 'Germany'], ['Ana Trujillo Emparedados y helados', 'Ana Trujillo', 'Owner', 'Avda. de la Constitucin 2222', 'Mxico D.F.', 'Mexico'], ['Antonio Moreno Taquera', 'Antonio Moreno', 'Owner', 'Mataderos 2312', 'Mxico D.F.', 'Mexico'] ], datafields: [ { name: 'CompanyName', type: 'string', map: '0' }, { name: 'ContactName', type: 'string', map: '1' }, { name: 'Title', type: 'string', map: '2' }, { name: 'Address', type: 'string', map: '3' }, { name: 'City', type: 'string', map: '4' }, { name: 'Country', type: 'string', map: '5' } ], datatype: 'array' }; dataAdapter: any = new jqx.dataAdapter(this.source); columns: any[] = [ { text: 'Company Name', datafield: 'CompanyName', width: 200 }, { text: 'Contact Name', datafield: 'ContactName', width: 150 }, { text: 'Contact Title', datafield: 'Title', width: 100 }, { text: 'Address', datafield: 'Address', width: 100 }, { text: 'City', datafield: 'City', width: 100 }, { text: 'Country', datafield: 'Country' } ]; }
MartinjQWidgets Team
