jQuery UI Widgets › Forums › Grid › rows not in correct order
This topic contains 4 replies, has 2 voices, and was last updated by Robin Kluth 11 years, 11 months ago.
since the latest update (2.9.0) I experienced the following:
Screenshot @ http://img.xrmb2.net/images/837313.png
My environment:
* jQWidgets 2.9.0
* jQuery 1.10.1
* YAML (CSS Framework) 4.0.2I have my grids inside a NavigationBar!
Grid-Code:
<div id="jqxGrid-proddb-fatjki-beitrag"></div> <script type="text/javascript"> var theme = getTheme();var settings_proddb_fatjki_beitrag = {height: 500, width: 800, theme: theme, altrows: true, sortable: false, columns: [ { text: 'Titel', datafield: 'title'} ,{ text: 'Keywords', datafield: 'proddb.fatjki.beitrag.07_KW.txt_d' } ], enabletooltips: true};$("#jqxGrid-proddb-fatjki-beitrag").jqxGrid(settings_proddb_fatjki_beitrag);$("#jqxGrid-proddb-fatjki-beitrag").on('bindingcomplete', function () { var localizationobj = {}; localizationobj.pagergotopagestring = "Gehe zu:"; localizationobj.pagershowrowsstring = "Zeige Zeile:"; localizationobj.pagerrangestring = " von "; localizationobj.pagernextbuttonstring = "voriger"; localizationobj.pagerpreviousbuttonstring = "nächster"; localizationobj.sortascendingstring = "Sortiere aufsteigend"; localizationobj.sortdescendingstring = "Sortiere absteigend"; localizationobj.sortremovestring = "Entferne Sortierung"; // apply localization. $("#jqxGrid-proddb-fatjki-beitrag").jqxGrid('localizestrings', localizationobj);});</script></div>
source & dataadapter:
var source = { datatype: "json", id: 'id', localdata: src[k].data }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxGrid-"+k).jqxGrid({source: dataAdapter}); $("#jqxGrid-"+k).jqxGrid('refreshdata');
Did you changed something with this update which could explain my issue?
Thanks in advance!
We cannot reproduce that. Please provide a sample which demonstrates the issue on your side. In addition, make sure that you updated the CSS Files, too.
http://www.jqwidgets.comThanks for your answer.
I’ve figured it out:
As I said before: I use YAML. I use the grid inside a .ym-form:
<form class="ym-form ym-columnar" onsubmit="return false;" id="result">
.ym-form has the following position style:
.ym-form div { position:relative; }
This is the issue – if I remove that css-style over Firebug it looks ok. I did not update YAML, I simply updated jQWidgets.
It does not matter which position is set: the grid always gets crashed – I have to remove the whole css entry for now. Do you changed something that could explain that behaviour?
Thanks in advance!
It seems to be a CSS conflict with your styles. If that is so, make sure that the jqx.base.css is with highest priority.
http://www.jqwidgets.comHi,
I’ve loaded the jqx.base.css as last stylesheet, but it does not work either.
I’ve fixed it by put the following after all other stylesheets:
.jqx-grid-cell { position: absolute !important; }/*applied to a grid cell that is part of a rows group.*/ .jqx-grid-group-cell{ position: absolute !important; }
The !important was the magic key – But I dont understand it: The stylesheet option, coming from YAML, cannot be overwritten – but it should..? There is no other !important and I have to set it for .jqx-grid-cell to get it back working.
Weird.
