jQuery UI Widgets Forums Grid rowCount in renderstatusbar problem
This topic contains 1 reply, has 2 voices, and was last updated by  Mariya 9 years, 8 months ago.
  • rowCount in renderstatusbar problem #78654
    melvin
    Hi, the renderstatusbar method isn’t work for me, please help !
    (if I un-mark the 2 line in renderstatusbar, Uncaught TypeError: Cannot read property ‘totalrecords’ of undefined )
    function loadrec(option,selectdate){
    url: ‘query.php?option=’+option+”&selectdate=”+selectdate,
    dataType: ‘json’,
    cache: false,
    { name: ‘uuid’ },
    root: ‘Rows’,
    sort: function()
    var zeroRenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
    if (value == 0) {
    return ‘ ‘;
    //var span = $(“<span id=’spanRowCount’></span>”);
    $(“#jqxgrid”).jqxGrid({
    source: source,
    theme: ‘classic’,
    sortable: ‘true’,
    //pageable: true,
    width: ‘810’,
    autoheight: ‘true’,
    virtualmode: true,
    altrows: true,
    showstatusbar: true,
    //pageable: true,
    rendergridrows: function(obj)
    return obj.data;
    //var rowCount = $(“#jqxgrid”).jqxGrid(‘getrows’).length;
    //statusbar.append(‘<div style=”margin: 5px;”>Rows count: <span id=”rowsCountSpan”>’ + rowCount’ + ‘</span></div>’);
    { text: ‘UID’, datafield: ‘uuid’, width: 50, cellsalign: ‘left’, cellsformat: ‘n5’ },
    $(“#jqxgrid”).on(“bindingcomplete”, function (event) {
    $(‘#rowsCountSpan’).text(rowCount);
    rowCount in renderstatusbar problem #78672
    Mariya
    Hi melvin,
    Can you please provide us with an example using https://www.jseditor.io/ in order for us to be more accurate?
    Best Wishes,
    Mariya
