jQuery UI Widgets › Forums › Grid › Row filter not working in grid inside tabs
This topic contains 1 reply, has 2 voices, and was last updated by Vladimir 9 years, 8 months ago.
Hello!
I have a jqxTabs with inside three object jqxGrid, all identical, they changing only for the contents.
Each jqxGrid is filterable and contains a filter row.
The filter is working ONLY in the first Grid, infact if I try to filter something in the others twos nothing appens.Every definitions of the grids are equals, I will post the first one:
`$(“#jqxgridclose”).jqxGrid(
width: ‘100%’,
height: ‘100%’,
selectionmode: ‘multiplerowsextended’,
source: dataAdapterChiusi,
groupable:
editmode: ‘dblclick’,//’click’, ‘dblclick’, ‘selectedcell’
showstatusbar: true,
columnsreorder: true,
altrows: true,
enabletooltips: true,
pagesize: 20,
pagesizeoptions: [5, 10, 15, 20, 25, 30, 40, 50, 60, 100],
showfilterrow: true,
});I’m posting also the jqxTabs definitions:
// initialize jqxTabs
$(“#jqxTabs”).jqxTabs({ theme: theme, width: ‘100%’, height: ‘100%’, position: ‘top’, selectionTracker: ‘checked’});//Selected event
$(“#jqxTabs”).on(‘selected’, function (event) {
var tab = $(“#jqxTabs”).val();
switch (tab) {
case 0:
$(“#jqxgriOpen”).jqxGrid(‘updatebounddata’);
break;
case 1:
$(“#jqxgridRev”).jqxGrid(‘updatebounddata’);
break;
case 2:
$(“#jqxgridclose”).jqxGrid(‘updatebounddata’);
break;
});Hello philler,
There is no reason why 3 grids should not work in 3 seperate tabs as long as they use their own variables.
You have probably copy/pasted a shared variable somewhere in your code and that could be preventing your grids from working.
Also please take a look at this demo on how to properly initialize your grids.Please create a jsfiddle or jseditor sample to demonstrate the issue.
VladimirjQWidgets team
