jQuery UI Widgets Forums Getting Started Row Detail issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 9 months ago.
  • Row Detail issue #59703
    lokesh masih
    In row detail jqxGrid i want to open one row detail at a time. suppose if i open another row then
    previous row detail should be closed. Is it possible please suggest me any solution.
    Row Detail issue #59715
    Hi lokesh masih,
    jqxGrid has a method called hidedetails for hiding row details. You can use it for hiding the row details which you want to hide.
