jQuery UI Widgets Forums TreeGrid Right-Click Clears Selected Rows
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 3 months ago.
  • Right-Click Clears Selected Rows #49951
    mdols
    I have a TreeGrid with a Context Menu that shows a modal Window to edit the selected rows (one or more). However, if you right-click to display the Context Menu without holding down the Ctrl key, the previously selected rows are un-selected. Is there a way to prevent rows from being un-selected on a right-click event? I tried handling the rowUnselect event, but wasn’t able to determine which mouse button was pressed to cause the row to be un-selected.
    Thank you,
    Mike
    Sample Code:
    treeGridControl.off(‘rowClick’).on(‘rowClick’, function (event) {
    var args = event.args;
    if (args.originalEvent.button == 2) {
    // Display Task Context Menu
    var treeGridId = getCurrentTaskTreeGridId();
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft,
    parseInt(event.args.originalEvent.clientY) – 310 + scrollTop);
    $(‘body’).addClass(‘modal-background’);
    return false;
    Right-Click Clears Selected Rows #49953
    Hi mdols,
    Unfortunately, there is no way to prevent the clearing on right-click.
