jQuery UI Widgets Forums Navigation Tree Problems with tree
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 10 months ago.
  • Problems with tree #5592
    ayanbizz
    var theme = getTheme();
    // Create jqxTree
    $('#jqxTree').jqxTree({ height: '400px', width: '300px', theme: theme });
    <div id='jqxTree' style='float: left; margin-left: 20px;'>
    <ul>
    <li>Consumer photo and video</li>
    <li>Mobile</li>
    <li>Rich Internet applications</li>
    <li>Technical communication</li>
    <li>Training and eLearning</li>
    <li>Web conferencing</li>
    <ul>
    <li>Web conferencing1</li>
    <li>Web conferencing2</li>
    </ul>
    </ul>
    I used the following code to create the tree view but problem is that I can’t see the left hand side arrows in the treeview and also I want to change the backgroud color of the treeview and I tried to do so in the style attribute of the div tag but it did not take any effect
    Problems with tree #5594
    ayanbizz
    Problems with tree #5595
    Hi ayanbizz,
    The HTML structure seems to be not correct.
    <ul>
    <li>Mobile</li>
    <ul>
    </ul>
    </li>
    </ul>
    To change the Tree’s background, you can edit the .jqx-tree and .jqx-widget-content styles in the CSS.
    Another approach is to set the background with code.
    For example:
    $("#jqxTree").css('background', '#ffbbaa');
    $("#jqxTree .jqx-widget-content").css('background', '#ffbbaa');
    Problems with tree #5602
    ayanbizz
    @Peter Stoev thanks for replying .Now ,I can change the background color of the tree view but I am not understanding what is wrong with the html code above.
    Problems with tree #5603
    Hi ayanbizz,
    A tree item is defined with LI tag. If you want to define sub-items for a tree item, then you need to define the UL before you close the LI tag.
