jQuery UI Widgets Forums Grid Problems with IE9 and JSON, no problems in chrome!
This topic contains 4 replies, has 2 voices, and was last updated by  rchasqueira 12 years, 3 months ago.
  • rchasqueira
    I was testing my jqxgrid with chrome and it works like a charme (really great job!!!), but now i’m testing it with IE 9, and the same page doesn’t have the same result. I’m getting the results from json, that gives me an array of two records. In chrome if i click form filter button with no specific filter, it shows the two lines, on IE no result found…
    If i filter with ID=’%1%’, chrome gives two records (correct), IE just gives one record (wrong). The array it’s well constructed, it’s just IE that is messing the grid.
    I also have another grid that open’s on first grid rowselect, in chrome it shows two relational lines(correct), in IE none (wrong)…
    Can you please help me? Did i forgot something or it’s an IE bug that you are aware of?
    Thanks in advanced!
    This is part of the code:
                var theme = "";
    			$("#jqxgrid").css("cursor", "pointer");
    			$("#NewEquip").click(function() {
                    $("#NewEquip").attr('href','GToolsEquipDetail.cshtml');
    				$("#NewEquip").colorbox({iframe:true, width:"1020px", height:"450px"});
                $("#EditEquip").click(function() {
                    var rowID = $("#jqxgrid").jqxGrid('selectedrowindexes');
                    if (rowID!=""){
                        $("#EditEquip").attr('href','GToolsEquipDetail.cshtml?ID=' + $("#ID_EQUIP").val());
    					$("#EditEquip").colorbox({iframe:true, width:"1020px", height:"450px"});
    				else{
    					alert("Não existe nenhum equipamento seleccionado");
    			$("#DelEquip").click(function () {
    				if (rowID!=""){
    					var row = $("#jqxgrid").jqxGrid('getrowdata', rowID);
    					if (confirm("Tem a certeza que deseja eliminar o equipamento " + row.ID_EQUIP + " - " + row.DESCRICAO + " ?")){
    						$("#CenterContent").load('GToolsActions.cshtml?op=1&EQUIP=' + row.ID_EQUIP);
    				else{
                $("#tabs li").click(function() {
                    if (!$(this).hasClass('active')){
    		            //	First remove class "active" from currently active tab
    		            $("#tabs li").removeClass('active');
    		            //	Now add class "active" to the selected/clicked tab
    		            $(this).addClass("active");
    		            //	Hide all tab content
    		            $(".tab_content").hide();
    		            //	Here we get the href value of the selected tab
    		            var selected_tab = $(this).find("a").attr("href");
    		            //	Show the selected tab content
    		            $(selected_tab).fadeIn();
                        $(selected_tab).css("visibility", "visible");
    		            //	At the end, we add return false so that the click on the link is not executed
    		            return false;
                                { name:'ID_EQUIP', type: 'String' },
                                { name:'DESCRICAO', type: 'String' },
                                { name:'NUM_AUXILIAR', type: 'String' },
                                { name:'N_SERIE', type: 'String' },
                                { name:'ID_TIPO_EQUIP', type: 'String' },
                                { name:'TIPO_EQUIP', type: 'String' },
                                { name:'ACTIVO', type: 'String' },
                                { name:'CATEGORIA', type: '' },
                                { name:'DELEGACAO', type: '' },
                                { name:'DT_ABATE', type: '' },
                                { name:'DT_ENTRADA', type: '' },
                                { name:'EMAIL_DELEGADO', type: '' },
                                { name:'EMAIL_SUPERVISOR', type: '' },
                                { name:'EMAIL_UTILIZADOR', type: '' },
                                { name:'ENTIDADE_CERTIF', type: '' },
                                { name:'ID_CATEGORIA', type: '' },
                                { name:'ID_DELEGACAO', type: '' },
                                { name:'ID_DELEGADO', type: '' },
                                { name:'ID_ENT_CERTIF', type: '' },
                                { name:'ID_MARCA', type: '' },
                                { name:'ID_MODELO', type: '' },
                                { name:'ID_SECTOR', type: '' },
                                { name:'ID_SUPERVISOR', type: '' },
                                { name:'ID_UTILIZADOR', type: '' },
                                { name:'INSPECCAO', type: '' },
                                { name:'LOGISTICA', type: '' },
                                { name:'MARCA', type: '' },
                                { name:'MODELO', type: '' },
                                { name:'NOME_DELEGADO', type: '' },
                                { name:'NOME_SUPERVISOR', type: '' },
                                { name:'NOME_UTILIZADOR', type: '' },
                                { name:'OBSERVACOES', type: '' },
                                { name:'PERIODICIDADE', type: '' },
                                { name:'PRECO', type: '' },
                                { name:'SECTOR', type: '' },
                                { name:'SH', type: '' },
     { name: 'SH_DESC', type: ''}
                    url: 'Xml.cshtml?VID=8&filtrar=1'
                    theme: 'classic',
                    width: '99%',
                    pagesize: 5,
                            pagesizeoptions: ['5','10'],
                    //showfilterrow: true,
                    altrows: true,
                    selectionmode: 'singlerow',
    { text: 'ID Equip', filtertype: 'textbox',  datafield: 'ID_EQUIP',  width: '10%', cellsalign: 'center', align: 'center'}, { text: 'Descrição', filtertype: 'textbox',  datafield: 'DESCRICAO',  width: '30%', cellsalign: 'left', align: 'center'}, { text: 'Nº Aux.', filtertype: 'textbox',  datafield: 'NUM_AUXILIAR',  width: '10%', cellsalign: 'center', align: 'center'}, { text: 'Nº Série', filtertype: 'textbox',  datafield: 'N_SERIE',  width: '15%', cellsalign: 'center', align: 'center'}, { text: 'Tipo', filtertype: 'textbox',  datafield: 'ID_TIPO_EQUIP',  width: '8%', cellsalign: 'center', align: 'center'}, { text: 'Descrição', filtertype: 'textbox',  datafield: 'TIPO_EQUIP',  width: '20%', cellsalign: 'center', align: 'center'}, { text: 'Activo', filtertype: 'textbox',  datafield: 'ACTIVO',  width: '7%', cellsalign: 'center', align: 'center'}, {hidden:'true',  text: 'CATEGORIA', filtertype: '',  datafield: 'CATEGORIA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'DELEGACAO', filtertype: '',  datafield: 'DELEGACAO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'DT_ABATE', filtertype: '',  datafield: 'DT_ABATE',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'DT_ENTRADA', filtertype: '',  datafield: 'DT_ENTRADA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'EMAIL_DELEGADO', filtertype: '',  datafield: 'EMAIL_DELEGADO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'EMAIL_SUPERVISOR', filtertype: '',  datafield: 'EMAIL_SUPERVISOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'EMAIL_UTILIZADOR', filtertype: '',  datafield: 'EMAIL_UTILIZADOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ENTIDADE_CERTIF', filtertype: '',  datafield: 'ENTIDADE_CERTIF',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_CATEGORIA', filtertype: '',  datafield: 'ID_CATEGORIA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_DELEGACAO', filtertype: '',  datafield: 'ID_DELEGACAO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_DELEGADO', filtertype: '',  datafield: 'ID_DELEGADO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_ENT_CERTIF', filtertype: '',  datafield: 'ID_ENT_CERTIF',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_MARCA', filtertype: '',  datafield: 'ID_MARCA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_MODELO', filtertype: '',  datafield: 'ID_MODELO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_SECTOR', filtertype: '',  datafield: 'ID_SECTOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_SUPERVISOR', filtertype: '',  datafield: 'ID_SUPERVISOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'ID_UTILIZADOR', filtertype: '',  datafield: 'ID_UTILIZADOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'INSPECCAO', filtertype: '',  datafield: 'INSPECCAO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'LOGISTICA', filtertype: '',  datafield: 'LOGISTICA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'MARCA', filtertype: '',  datafield: 'MARCA',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'MODELO', filtertype: '',  datafield: 'MODELO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'NOME_DELEGADO', filtertype: '',  datafield: 'NOME_DELEGADO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'NOME_SUPERVISOR', filtertype: '',  datafield: 'NOME_SUPERVISOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'NOME_UTILIZADOR', filtertype: '',  datafield: 'NOME_UTILIZADOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'OBSERVACOES', filtertype: '',  datafield: 'OBSERVACOES',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'PERIODICIDADE', filtertype: '',  datafield: 'PERIODICIDADE',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'PRECO', filtertype: '',  datafield: 'PRECO',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'SECTOR', filtertype: '',  datafield: 'SECTOR',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'SH', filtertype: '',  datafield: 'SH',  width: '10%', cellsalign: '', align: ''}, {hidden:'true',  text: 'SH_DESC', filtertype: '',  datafield: 'SH_DESC',  width: '10%', cellsalign: '', align: ''}
                $("#excelExport").click(function () {
                    $("#jqxgrid").jqxGrid('exportdata', 'xls', 'jqxGrid');
                $("#csvExport").click(function () {
                    $("#jqxgrid").jqxGrid('exportdata', 'csv', 'jqxGrid');
    This is the json result:
    [{"ID_EQUIP":"D000001","DESCRICAO":"sadasdas","NUM_AUXILIAR":"123123","N_SERIE":"123123","ID_TIPO_EQUIP":"ANR","TIPO_EQUIP":"Analizador de Rede","ACTIVO":"S","CATEGORIA":"Dispositivos de Monitorização e Medição","DELEGACAO":"Algarve","DT_ABATE":null,"DT_ENTRADA":"2013-01-17","EMAIL_DELEGADO":null,"EMAIL_SUPERVISOR":"Alberto.Proenca@otis.com","EMAIL_UTILIZADOR":"Rui.Abreu@otis.com","ENTIDADE_CERTIF":"OTIS","ID_CATEGORIA":"1","ID_DELEGACAO":"41","ID_DELEGADO":null,"ID_ENT_CERTIF":"3","ID_MARCA":"1","ID_MODELO":"2","ID_SECTOR":"MT","ID_SUPERVISOR":"06110","ID_UTILIZADOR":"01125","INSPECCAO":"N","LOGISTICA":"N","MARCA":"Amprobe","MODELO":"RS-5","NOME_DELEGADO":null,"NOME_SUPERVISOR":"ALBERTO DOS SANTOS PROENCA","NOME_UTILIZADOR":"ALCINO RUI PINTO ARAUJO ABREU","OBSERVACOES":"","PERIODICIDADE":12,"PRECO":null,"SECTOR":"Montagem","SH":"9021","SH_DESC":"PROMOCAO E PUBLICIDADE"},{"ID_EQUIP":"F000001","DESCRICAO":"sdfsdfdsf","NUM_AUXILIAR":"324234234","N_SERIE":"21312313","ID_TIPO_EQUIP":"ARC","TIPO_EQUIP":"Ar Condicionado","ACTIVO":"S","CATEGORIA":"Ferramentas Elétricas","DELEGACAO":"Atelda","DT_ABATE":null,"DT_ENTRADA":"2013-01-07","EMAIL_DELEGADO":null,"EMAIL_SUPERVISOR":"antonio.m.santos@otis.com","EMAIL_UTILIZADOR":"Rui.Abreu@otis.com","ENTIDADE_CERTIF":"ISQ","ID_CATEGORIA":"2","ID_DELEGACAO":"16","ID_DELEGADO":null,"ID_ENT_CERTIF":"1","ID_MARCA":"2","ID_MODELO":"3","ID_SECTOR":"LG","ID_SUPERVISOR":"06105","ID_UTILIZADOR":"01125","INSPECCAO":"N","LOGISTICA":"N","MARCA":"Beha","MODELO":"UNITEST","NOME_DELEGADO":null,"NOME_SUPERVISOR":"ANTONIO MANUEL FILIPE DOS SANTOS","NOME_UTILIZADOR":"ALCINO RUI PINTO ARAUJO ABREU","OBSERVACOES":"","PERIODICIDADE":12,"PRECO":null,"SECTOR":"Logística","SH":"902","SH_DESC":"COMUNICACAO E IMAGEM"}]
    Hi rchasqueira,
    If you enter the following string in the filter textbox:
    “ID=’%1%’”, the filter’s value would be set to “ID=’%1%’” .
    For example, for the default “contains” filter condition, the Grid will loop through all cells and will check whether the current cell value contains the “ID=’%1%’” string. That’s how it works in all browsers.
    Btw. type: ” is invalid type and type: ‘String’ should be written as type: ‘string’.
    rchasqueira
    Thanks for your response, but i think i didn’t explain my self very well.
    I have a form in the page with some fields to filter the results to list on the grid. When i click the submit button, i build a string a that I put in JQXGRID URL parameter. This string calls a page that reads the parameters, queries the database and returns an JSON array to build the grid.
    The GRID is build with the result from the form and then i can use the filter of the jqxgrid.
    There is no problem with the filter, the result is correct and well formed and chrome handles with perfectly, but IE9 in some cases doesn’t returns any value at all…
    I can’t understand this…I have browser console opened in both browsers, but there’s no error return in either one…
    Hi rchasqueira,
    IE caches Ajax calls so that may be an issue, if you dynamically make such calls. In the “source” object you can set “cache: false”.
    rchasqueira
    Hi Peter!
    Sorry for the delay.
    That was the case, with “Cache: false”, my problems are gone.
    Thanks for your help. You rock!
    Ricardo
