jQuery UI Widgets Forums Grid Problems with grid size in container
This topic contains 2 replies, has 2 voices, and was last updated by  cyclop 10 years, 9 months ago.
  • Problems with grid size in container #60521
    cyclop
    I’m trying to solve the next trouble. Where I load a page, the grid doen’t fill all the div in the first load, but when I change to another page (the grid has paging) this grid fill all.
    I’ve attachet 2 images:
    First load
    Changing page
    Thanks!!
    Problems with grid size in container #60571
    Hello cyclop,
    Please provide us with a code example demonstrating the issue (preferably at JSFiddle), so that we may be able to assist you.
    Problems with grid size in container #60583
    cyclop
    Finally, I solved it!! 😀
    I use the jqxgrid inside a DIV wih jquery method .show(‘slow’)
    First I load de grid and after that, when you press a button, the container div execute .show(‘slow’). jqxgrid has the size of the container div and, in the execution, jqxgrid reder again with the showing size.
    Now i change ‘slow’ to ‘fast’ and put the code after this method.
    Regards and many thanks.
