jQuery UI Widgets Forums Grid Problem with virtual loading
This topic contains 2 replies, has 2 voices, and was last updated by  Hristo 5 years, 3 months ago.
  • Problem with virtual loading #108166
    ajcs
    I have a problem with the virtual mode of the grid. I have made an example. When scrolling down a page it does not draw the second page correctly:
    Example
    I also have secondary questions that I have put as comments in the code:
    1. Why is the data source url+datatype needed when I am doing the data fetching myself. If you leave them out it does not call loadServerData.
    2. Why is rendergridrows needed when it is already calling the data adapter again to load the data.
    Problem with virtual loading #108172
    ajcs
    I have fixed the main problem with the page draw. I did not understand to start the returned array indexing at the startindex
    Fixed
    But I would still like to know the answer to the questions above – thanks.
    Problem with virtual loading #108219
    Hello ajcs,
    The rendergridrows callback, it returns an array of records and if you need to update the records.
    I would like to suggest you look at this forum topic.
    https://www.jqwidgets.com
