jQuery UI Widgets Forums Grid Problem with StatusBar and Aggergates
This topic contains 7 replies, has 4 voices, and was last updated by  TP_DTNA 9 years, 4 months ago.
  • Problem with StatusBar and Aggergates #13650
    DavidSimmons
    In this example my status bar works great until I set showaggregates: true. Then my status bar disappears. Can you help me with this?
    $(jqxgrid).jqxGrid({
    width: ‘99.9%’,
    height: 300,
    scrollbarsize: 10,
    sorttogglestates: 1,
    altrows: true,
    virtualmode: false,
    enablehover: false,
    enabletooltips: false,
    autoheight: false,
    autosavestate: false,
    autoloadstate: false,
    columnsreorder: false,
    selectionmode: “singlecell”,
    showfilterrow: true,
    statusbarheight: 26,
    showstatusbar: true,
    showaggregates: true,
    var container = $(“
    var table = $(“”);
    table.appendTo(container);
    var tableRow = $(“”);
    tableRow.appendTo(table);
    var tableLeft = $(“”);
    tableLeft.appendTo(tableRow);
    var tableCenter = $(“”);
    tableCenter.appendTo(tableRow);
    var tableRight = $(“”);
    tableRight.appendTo(tableRow);
    var refreshButton = $(“
    refreshButton.find(‘span’).addClass(‘ui-icon ui-icon-refresh’);
    refreshButton.width(16);
    refreshButton.jqxTooltip({ content: ‘Refresh Grid!’, position: ‘mouse’, name: ‘Tooltip’, theme: theme });
    refreshButton.appendTo(tableLeft);
    var recalculateButton = $(“
    recalculateButton.find(‘span’).addClass(‘ui-icon ui-icon-arrowstop-1-n’);
    recalculateButton.width(16);
    recalculateButton.jqxTooltip({ content: ‘Recalculate!’, position: ‘mouse’, name: ‘Tooltip’, theme: theme });
    recalculateButton.appendTo(tableLeft);
    var pagingLabel = $(“
    pagingLabel.text(“Records”);
    pagingLabel.appendTo(tableCenter);
    statusbar.append(container);
    refreshButton.click(function (event) {
    $(jqxgrid).jqxGrid(‘updatebounddata’);
    recalculateButton.click(function (event) {
    if(selectedID>0){
    $(“#message”).html(“Recalculate”);
    type: “POST”,
    url: “../Bid/BidRecaculateJSON.php”,
    data: { BidID: selectedID}
    }).done(function( msg ) {
    $(“#message”).html(“Transaction: ” + msg);
    }else{
    $(“#message”).html(“You must select a Bid!”);
    Problem with StatusBar and Aggergates #13660
    Hi David,
    The Grid’s Column Aggregates are displayed in the StatusBar area. You are not able to render custom widgets into that area in case you wish the built-in aggregates to be displayed.
    Problem with StatusBar and Aggergates #13701
    DavidSimmons
    Thanks…
    Problem with StatusBar and Aggergates #13702
    DavidSimmons
    Do you plan to correct the issue with the Aggregator returning incorrect results when the column does not contain values for each row.
    Problem with StatusBar and Aggergates #13703
    Hi David,
    Please, provide a sample which demonstrates the new issue that you have.
    Problem with StatusBar and Aggergates #15332
    Example:
    2 columns
    Product a = 10
    Product b = 0
    Product c = 10
    product d = 0
    product e = 0
    Aggregates ‘avg’ return 20/5 = 4 instead I need 20/2 = 10
    Is it possible?
    Marco
    Problem with StatusBar and Aggergates #15618
    anyone?
    Problem with StatusBar and Aggergates #80538
    TP_DTNA
    Is it a solution to just implement a custom aggregate function, one that ignores rows you don’t want in the average?
    There’s a aggregate property in the column definition, looks like:
    aggregates: [‘count’, {
    ‘Cappuccino Items’: function (aggregatedValue, currentValue) {
    if (currentValue == “Cappuccino”) {
    return aggregatedValue + 1;
    return aggregatedValue;
    example seen here: http://jsfiddle.net/jqwidgets/3y7RN/
