jQuery UI Widgets Forums Layouts Splitter Problem with spliter’ height
This topic contains 2 replies, has 3 voices, and was last updated by  stephan 11 years, 12 months ago.
  • Problem with spliter’ height #22144
    NeverGiveUp
    I am having problem with spliter height. I have two panels in spliter. left panel my menu goes and right panel my dynamic big content goes.   But the content is not fluid and not the panel doesn’t expand against its content. And when i give splietr heiht is 100%, it is not working/
    Please help me.
    Thank You
    Problem with spliter’ height #22167
    I am not sure what’s wrong on your side, but jqxSplitter supports Width and Height in percentages. Please, provide a sample which we will be able to run and which illustrates your scenario.
    Example:
    <meta name="keywords" content="jQuery Splitter, Splitter Widget, Splitter, jqxSplitter" />
    <meta name="description" content="This page demonstrates splitter's events" />
    <title id='Description'>This demonstration shows how to create a splitter that fits the entire browser window's contents.
    </title>
    <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script>
    $('#splitter').jqxSplitter({ width: '100%', height: '100%', panels: [{ size: '20%', min: 150 }, { size: '80%', min: 250}] });
    <style type="text/css">
    html, body
    height: 100%;
    width: 100%;
    margin: 0px;
    padding: 0px;
    overflow: hidden;
    </style>
    <body>
    <div id='splitter'>
    <div></div>
    <div></div>
    Problem with spliter’ height #22935
    stephan
    I think I understand the height problem, because I also encountered a height problem when first testing out splitters. The following fiddle shows my problem and also how I fixed it:
    http://jsfiddle.net/ZUNvp/2/
    In order to have jqxWidget apply a 100% height correctly it must be located within a container div that itself has an actual height. This can be resolved as shown in my fiddle: by adding e.g. 100% to the container, orby placing the splitter into an absolutely positioned and sized container.
    Stephan
