jQuery UI Widgets Forums Chart Problem with Spacing
This topic contains 1 reply, has 2 voices, and was last updated by  Ivo Zhulev 9 years, 1 month ago.
  • Problem with Spacing #85387
    George S
    I have a chart which displays 3 or 4 rows of data, basically for people. Each row has 3 series. I want all the data for the first person to be charted together, no spaces, then for the 2nd person, all the data (aka all 3 bars) should be touching, then a space until the 3rd person, and all 3 bars should be touching. I have played around with seriesGapPercent and columnGapPercent, and I cannot get the chart to look any different. If I have 3 people, I have 9 bars, and all 9 bars are evenly spread out across the whole chart. What I want is 3 bars, a space, 3 bars, a space, and then 3 bars. I have seen the column Series spacing demo, and I think I am using the right parameters, I just can’t get it to display properly.
    Here is my code…
     // Set our source array to ''
            var source = {
                localdata: data5,
                root: 'rows',
                { name: 'TERRITORY_FIELD_RM', type: 'string' },
                { name: 'MGR_NAME', type: 'string' },
                { name: 'MYTOTAL_COUNT', type: 'number' },
                { name: 'MYACTIVE_COUNT', type: 'number' },
                { name: 'MYINACTIVE_COUNT', type: 'number' },
                { name: 'MYYTD_PAAS_COUNT', type: 'number' },
                { name: 'MYYTD_ON_PREM_COUNT', type: 'number' },
                { name: 'MYEXISTING_ACTIVE', type: 'number' }
                ]  }; // SOURCE
    			autoBind: true,
    			async: false,
    			downloadComplete: function () { },
    			loadError: function () { }
                // prepare jqxChart settings
                var settings1 = {
                    title: "New Accounts",
                    description: accountQtr,
                    enableAnimations: false,
                    showLegend: true,
                    xAxis:
                            dataField: 'MGR_NAME',
                            unitInterval: 1,
                            axisSize: 'auto',
                            tickMarks: {
                                visible: true,
                                interval: 1,
                                color: '#BCBCBC'
                            gridLines: {
                                visible: true,
                                interval: 1,
                                color: '#BCBCBC'
                    valueAxis:
                        flip: true,
                        //unitInterval: 10,
                        minValue: 0,
                       // maxValue: 120,
                        title: { text: 'Accounts By Manager' },
                        labels: { horizontalAlignment: 'right' },
                        tickMarks: { color: '#BCBCBC' }
                    colorScheme: 'scheme05',
                    seriesGroups:
                                showLabels: true,
                                type: 'stackedcolumn',
                                columnsMaxWidth: 30,
                                columnsMinWidth: 30,
                                skipOverlappingPoints: false, // change to true if you want to prevent adjacent columns overlap
                                orientation: 'horizontal',
                                columnsGapPercent: 5,
                                seriesGapPercent: 5,
                                series: [
                                      { dataField: 'MYINACTIVE_COUNT', displayText: 'InActive/Greenfield On-Premise'}
                                showLabels: true,
                                series: [
                                    { dataField: 'MYEXISTING_ACTIVE', displayText: 'Active On-Premise'},
                                    { dataField: 'MYYTD_ON_PREM_COUNT', displayText: 'YTD New On-Prem Wins'}
                                showLabels: true,
                                series: [
                                    { dataField: 'MYYTD_PAAS_COUNT', displayText:'YTD New Cloud Wins'}
                // setup the New Accounts chart
                $('#newAccounts_chart').jqxChart(settings1);
    Problem with Spacing #85390
    Ivo Zhulev
    Hi George S,
    Can you please send us a working fiddle?
    Ivo
