jQuery UI Widgets Forums Grid Problem with showing a date
This topic contains 9 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 3 months ago.
  • Problem with showing a date #51183
    wormie007
    My problem is that my database (Microsoft SQL Server) I have a date field, but to display it in the grid using internet explorer, the date time aren’t correctly displayed.
    using the following line:
    {text: ‘Date’, ColumnGroup: ‘Events’ datafield’ Date ‘, cellsformat:’ dd-MM-yyyy HH: mm: ss’, width: ‘28% ‘},
    the hour an minutes aren’t correctly, it appears 01 in hour and 00 in minutes.
    How can i solve it?
    I use internet explorer 8.0.7601.17514
    Problem with showing a date #51185
    Ho wormie007,
    Sometimes, it is necessary to describe your date’s format when you define the data fields array of your data source object.
    Ex: { name: ‘SubmitDate’, type: ‘date’, format: “yyyy-MM-ddTHH:mm:ss-HH:mm” }
    Problem with showing a date #51191
    wormie007
    Sorry but it doesn’t work.
    Do you knwo another possible cause for this kind of problem?
    Problem with showing a date #51193
    Hi wormie007,
    Could you send us a sample which demonstrates your scenario and we will take a look at it?
    Problem with showing a date #51197
    wormie007
    datatype: “xml”,
    { name: ‘IdAplicacion’, type: ‘int’ },
    { name: ‘Categoria’, type: ‘string’ },
    { name: ‘Fecha’, type: ‘date’, format: ‘yyyy-MM-ddTHH:mm:ss-HH:mm’ },
    { name: ‘Usuario’, type: ‘string’ },
    { name: ‘Ubicacion’, type: ‘string’ },
    { name: ‘Descripcion’, type: ‘string’ },
    { name: ‘Contenido’, type: ‘string’ }
    async: false,
    record: ‘Table’,
    pagesize: 10,
    url: ‘Metodos.aspx/GetEvento’
    $(“#jqxgrid”).jqxGrid(
    width: ‘80%’,
    editable: false,
    statusbarheight: 45,
    showtoolbar: true,
    filterable: false,
    autorowheight: false,
    columnsreorder: true,
    autoshowfiltericon: false,
    var container = $(“<div style=’text-align:center;’></div>”);
    var title = $(“<b>Administracion de Eventos</b>”);
    container.append(title);
    toolbar.append(container);
    { text: ‘Id Aplicacion’, columngroup: ‘Eventos’, datafield: ‘IdAplicacion’, width:’12%’ },
    { text: ‘Categoria’, columngroup: ‘Eventos’, datafield: ‘Categoria’, width: ‘12%’ },
    {text: ‘Fecha’, columngroup: ‘Eventos’, datafield: ‘Fecha’, cellsformat: ‘dd-MM-yyyyTHH:mm:ss’, width: ‘28%’ },
    { text: ‘Usuario’, columngroup: ‘Eventos’, datafield: ‘Usuario’, width: ‘12%’ },
    { text: ‘Ubicacion’, columngroup: ‘Eventos’, datafield: ‘Ubicacion’, width: ‘12%’ },
    { text: ‘Descripcion’, columngroup: ‘Eventos’, datafield: ‘Descripcion’, width: ‘12%’ },
    { text: ‘Contenido’, columngroup: ‘Eventos’, datafield: ‘Contenido’, width: ‘12%’ },
    columngroups: [
    { text: ‘Eventos’, align: ‘center’, name: ‘Eventos’ }
    I think this is all you needed.
    Problem with showing a date #51217
    Hi wormie007,
    That’s almost what I need. Could you send a sample of your data so I can check whether the “format” is correct for your case. It should match the Date format of your data source.
    Problem with showing a date #51236
    wormie007
    a sample of a date that i have in my source is like 14/03/2014 17:09:44
    Problem with showing a date #51238
    Hi wormie007,
    This means that the format for you should be: format: ‘dd/MM/yyyy HH:mm:ss’
    Problem with showing a date #51239
    wormie007
    I have tested in firefox and it works fine, but in internet explorer that i cite you above, it doesn’t work, and would need to be for the explorer. Have you kow a patch or something to solve it?
    Problem with showing a date #51261
    Hi wormie007,
    We cannot reproduce such issue with IE8 which means that we cannot provide a patch for something which we can’t verify. If you wish, provide a sample which demonstrates a problem and which we can test, because the code from your post does not have data and we can’t test it in the way it is now. You can use jsfiddle.net to prepare online sample.
